![]() | Home > Technical (L322) > Westafalia key |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Well I've just found the 2 keys for mine where they were supposed to be. I was looking for normal keys before, not great lumps of red plastic, which were in a bag. The swan neck weighs a ton !
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
HGVDriver - hope this helps
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Just to add to Nick's write up above... When fitting you need to lock the bar and remove the key! If the key WONT lock/release, the bar is NOT installed correctly and is at risk of coming off whilst using!!! |
Ah yes, good point Craig - cheers Current Fleet:-
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 ![]() ![]() |
thanks fellas i shall have another go tomorrow (its a bit rusty and need a coat of hammerite )thou i dont tow anything with the car its handy to have the wife wont let me buy a caravan |
