![]() | Home > Technical (L322) > Westafalia key |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Is this what you are looking for?
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
Thanks for that. The lock only has a three digit code, so I assume it would be 2Wxxx. |
No unfortunately the the key numbers are 4 digit starting 2W** so l don't think you have the key number.
Ok the lock number and the key number are different on mine too
Thanks! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
the key is often found, in the boot storage bin, where the hook normally is stored. if your hook is on, you might not be aware it should be in front right of luggage area in a flip lid box. go to westfalia site, and send decent picture of the key slot, thay can send you a key, maybe with proof you own the car. |
Unfortunately the car had the armature, but no bar. I've acquired a bar on eBay, but it came (knowingly) without a key, just trying to sort that out!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
the key number probably corresponds to the lock number on some database somewhere, a good pic of the barrel and an email to westfalia should sort it.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I managed to get a replacement key for my Bosal / Oris hitch on the Mercedes ml... the number on the hitch is nothing like the number on the key
I don't know where abouts in Warwickshire you is, but there are 3 stockists in the Warwick area ![]() https://www.westfalia-automotive.com/uk/stockists/ Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I have no key for mine. I have the number. Westfalia want £22 for a key.
You can get the key cut for less than a fiver online if you know the key number -just google Westfalia key cutting Current Fleet:-
![]() ![]() ![]() ![]() I paid a tenner for my Mercedes Key, and I thought that was a bit OTT...... But £22? Is it gold plated? Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Well I went to my local Westfalia towbar dealer this afternoon. Apparently there is only one master key set which has a waiting list.
Just ordered one off the bay for £3.60. My number doesn't start 2W, but 5 numbers, so I hope what I was told to order is correct... 2011 Range Rover Vogue SE 4.4 TDV8
