Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android
Page 31 of 36 <123 ... 303132 ... 343536>
miggit
Whistle I think that someone needs to edit their profile... it defiantly says 2004 TD6.... Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #379690 27th Mar 2016 9:51pm
p38arover
Australia
But why are they so defiant? Razz Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #379701 27th Mar 2016 11:11pm
THIS THREAD WILL NOT WORK WITH A TOUCHSCREEN HEAD UNIT
Now do we think that will do.....?? Pete
Post #379702 27th Mar 2016 11:39pm
miggit
Idea I think I've spotted the problem...... Whistle someone, Pete, has titled it "2002 - 2006 Replacement head unit running Android" Shocked
Whistle Shouldn't that be "2002 - almost 2005, and if the screen changes when you touch it Censored off, Replacement head unit running Android " Razz Yesterday I couldn't spell Engineer... Today I are one!
Post #379707 28th Mar 2016 12:49am
There are non-touch screen 2006 ones about though...
I'll put something on the first page... Pete
Post #379708 28th Mar 2016 1:34am
miggit
Shocked So Land Rover produced parts bin clearance specials too Shocked
A pal of mine used to work for Vauxhall on the CF van line, as a body finisher, he tells of the sudden upgrade to the CF van to use up all the door furniture that was left over from the Viva Deluxe after it had finished Shocked Sounds like L/R discovered that they had a few more stillages full than they originally thought Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #379728 28th Mar 2016 8:30am
sheps
hi,
fair play guys, first i put it as 2004 as my rr is a 54 but regd in january 2005 which is a change over front so thought it best,
i did sort of read the posts backwards thinking all was great and now realise i should of started from the front, all i was really after was getting my android prone to show its phone book and the tv to work on digital, tv not the important, and it might be easier to get a parrot.
but now i have read through the post fair play to all those that put the hard work in Thumbs Up
Post #379742 28th Mar 2016 10:03am
Weegie
Although not in your case, I think one of the problems is that people tend to put the date of registration as the year of the vehicle when doing their profile. Using the model year instead helps to get more accurate answers to a query.
For example my FFRR was first registered on 1st October 2004 but is MY2005 so that is what I have in my profile. Especially as it was a changeover to touch screen and MOST John
GAP iiD BT
Post #379750 28th Mar 2016 10:39am
jetset
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
If you are replacing the lot, or tapping into just speakers then you can fit any unit? Maybe the wheel controls may be a concern?
Post #379813 28th Mar 2016 5:13pm
Yes you can but you lose the "other" things the head unit does, the FBH timer, clock setting and fuel computer with the early BMW FF's and a whole lot more on the later ones....
You can get a blanking plate with a double din size hole to fit the FF (well BMW actually but it will fit) and then use any double din head unit you like... Thumbs Up Pete
Post #379819 28th Mar 2016 5:54pm
Donnor
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Haylands,
I'm interested if you have any suggestions as to which current model of unit is best purchased ? Looking specifically for DAB radio as well as the usual sat nav etc, having a vogue on a '53 plate with DSP I'm also looking for advice on the canbus integration and how to successfully bypass the amp
Post #391275 11th Jun 2016 5:44pm
I'm no ICE expert, all I know is in this thread and the fitting thread, as for which one is best you will have to research that yourself from all the adverts .... Pete
Post #391423 12th Jun 2016 7:39pm
Kendog
England 2004 Range Rover HSE 4.4 V8 Java Black
Afternoon boys I've not been on here for a while but have my RR booked in tomorrow morning to have my new Erisin ES2053B head unit fitted aswell as s Kicker amplifier 2 X 8" kickers subs fitted and a set of 3-way focal components and 2-way focals in the rear done can't wait I'll upload some pics when I pic it up 👌👌👌👌
Post #393146 26th Jun 2016 2:45pm
Kendog
So it's all finally in and everything is working perfect...
I've attached some pictures for everyone to look at.
Post #394163 2nd Jul 2016 5:32pm
RR2008HSE
Nice! I specifically got a 2008 to get the newer nav/stereo. That was before knowing how you could update the old ones so much more easily. That looks great and very "factory".
Post #394183 2nd Jul 2016 7:43pm
