![]() | Home > General > Tdv8 RR -High Mileage? |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 353 ![]() ![]() ![]() |
Whilst I've not owned it long, just 7 months or so, I can say mine runs as sweet as anything. The interior is holding up to the miles, and it's ivory. I think mileage is around the 143,000. TDV8 seems to attract attention re turbos. but hey, these things could go at any time I suppose.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
glad to hear its still running strong.
Northern Monkey, you can tell him that it's a tremendous car. All it's had is a drop link, or whatever they are called, the WD40 fix on the rear wiper, a few cans of BG diesel cleaner, a few tanks of super diesel and a load of polish.
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
I've got mine up to 108k now and its running smooth as a smooth thing that's been ironed (apparently cause I've never touched the iron at home) |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
Mines is now at 154k |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
Mine has just ticked over 200,000 klms.
Any of these posts helped but your mind at ease OP? |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
I have some questions..
I think with age any part can go on any car, biggest issue I find is sticky turbo actuator but it's easily cured.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The TDV8s use the 6 Speed ZF autoboxes, think it's either the ZF6HP26 or the ZF6HP28, but either variant should be significantly better than the 5 Speed GM autobox, the 'infamous' GM5L40E, used in the TD6.
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
I took the plunge and purchased a high mileage TDV8. To be honest, I rather prefer high mileage because, this usually means alot of the common faults have been fixed.
The turbo issue is expensive, because the advise is that you must change both at the same time.
Zigzagsky Member Since: 18 Oct 2015 Location: Sandhurst Posts: 39 ![]() ![]() ![]() |
Stick it on a diagnostic tool and you should get an idea what the issue is since going into limp mode will generate an error code.
limp home mode could be being caused by the rather notorious split turbo hose.
