Home > General > Tdv8 RR -High Mileage? |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 345 |
Whilst I've not owned it long, just 7 months or so, I can say mine runs as sweet as anything. The interior is holding up to the miles, and it's ivory. I think mileage is around the 143,000. TDV8 seems to attract attention re turbos. but hey, these things could go at any time I suppose.
30th Jan 2016 3:51pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
glad to hear its still running strong.
30th Jan 2016 5:02pm |
Northern Monkey, you can tell him that it's a tremendous car. All it's had is a drop link, or whatever they are called, the WD40 fix on the rear wiper, a few cans of BG diesel cleaner, a few tanks of super diesel and a load of polish.
30th Jan 2016 7:47pm |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
I've got mine up to 108k now and its running smooth as a smooth thing that's been ironed (apparently cause I've never touched the iron at home) 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
31st Jan 2016 12:11am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
Mines is now at 154k Got - 2017 SDV8 Autobiography in Loire Blue
31st Jan 2016 12:16am |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 |
Mine has just ticked over 200,000 klms.
1st Feb 2016 5:01pm |
Any of these posts helped but your mind at ease OP? |
2nd Feb 2016 12:18pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
I have some questions..
3rd Feb 2016 11:22am |
I think with age any part can go on any car, biggest issue I find is sticky turbo actuator but it's easily cured.
3rd Feb 2016 1:08pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The TDV8s use the 6 Speed ZF autoboxes, think it's either the ZF6HP26 or the ZF6HP28, but either variant should be significantly better than the 5 Speed GM autobox, the 'infamous' GM5L40E, used in the TD6.
3rd Feb 2016 2:44pm |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
I took the plunge and purchased a high mileage TDV8. To be honest, I rather prefer high mileage because, this usually means alot of the common faults have been fixed.
3rd Feb 2016 11:45pm |
The turbo issue is expensive, because the advise is that you must change both at the same time.
4th Feb 2016 5:14am |
Zigzagsky Member Since: 18 Oct 2015 Location: Sandhurst Posts: 39 |
Stick it on a diagnostic tool and you should get an idea what the issue is since going into limp mode will generate an error code.
5th Feb 2016 12:48pm |
limp home mode could be being caused by the rather notorious split turbo hose.
5th Feb 2016 7:52pm |
