Home > General > Tdv8 RR -High Mileage?
Page 1 of 3 123>
theanswers
Ireland
I'm coming back to the RR field after 8 months in a Disco 3. Just fancied a upgrade.
What mileage are TDV8s generally good for, due to my budget I'm looking at the higher end of the market with approx 160000-200000 miles. Is this alot? Do they give much bother? Thumbs Up
Post #369560 30th Jan 2016 3:16pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Whilst I've not owned it long, just 7 months or so, I can say mine runs as sweet as anything. The interior is holding up to the miles, and it's ivory. I think mileage is around the 143,000. TDV8 seems to attract attention re turbos. but hey, these things could go at any time I suppose.
My advice, after struggling with a similar decision is to go for it, if it is only the miles holding you back and the rest of the car seems fine.
Post #369567 30th Jan 2016 3:51pm
glad to hear its still running strong.
will report it to the original owner, he was never as happy with its replacement as he was with the 3.6, and is now in a disco! There is nothing that can't be fixed with a hammer😜😜
Post #369582 30th Jan 2016 5:02pm
archermav
Northern Monkey, you can tell him that it's a tremendous car. All it's had is a drop link, or whatever they are called, the WD40 fix on the rear wiper, a few cans of BG diesel cleaner, a few tanks of super diesel and a load of polish.
Sorry OP Embarassed for derailment.
Post #369606 30th Jan 2016 7:47pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
I've got mine up to 108k now and its running smooth as a smooth thing that's been ironed (apparently cause I've never touched the iron at home) Laughing 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #369638 31st Jan 2016 12:11am
Mines is now at 154k Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #369639 31st Jan 2016 12:16am
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Mine has just ticked over 200,000 klms.
Its had two new turbos fitted when I bought it by a very good indie who spotted smoke!
Other than that seems okay.
Cheers, Jerry
Post #369936 1st Feb 2016 5:01pm
archermav
Any of these posts helped but your mind at ease OP?
Post #370066 2nd Feb 2016 12:18pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
I have some questions..
1. Is it a case of when the turbos go rather than if ?
2. Why is their repair/ replacement so expensive ?
3. Whats the gear box situation with the TdV8 ? Is it as bad as the Td6 ?
4. Any known issues with the injectors ?
Post #370251 3rd Feb 2016 11:22am
MachineHead
I think with age any part can go on any car, biggest issue I find is sticky turbo actuator but it's easily cured.
The turbo s about £800 and it's location adds to cost in labour, is hidden above nearside diff - offside is way easier and has less issues imo
never had a td6 or issues but someone wise will no doubt be along shortly Thumbs Up
No idea about injector issues all I can say is not had any Very Happy 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #370270 3rd Feb 2016 1:08pm
Discotigger
The TDV8s use the 6 Speed ZF autoboxes, think it's either the ZF6HP26 or the ZF6HP28, but either variant should be significantly better than the 5 Speed GM autobox, the 'infamous' GM5L40E, used in the TD6.
The only caveat I would suggest is to ensure the gearbox oil and filters have been changed, I think the TDV8 service manual mentions this should be done at around 75,000 miles, but don't quote me on that.
Post #370300 3rd Feb 2016 2:44pm
theanswers
Ireland
I took the plunge and purchased a high mileage TDV8. To be honest, I rather prefer high mileage because, this usually means alot of the common faults have been fixed.
It's a Vogue SE, I got it at what I think is good money. Potentially it has turbo issues, but it could be anything. It goes into limp mode every now and again, but once restarted works perfectly. Perhaps a turbo actuator, EGR Valve, split pipe. I really don't believe it actually is a turbo fault, however if it is I will cross that bridge then.
Won't have time to look at it properly for the next few weeks.
It has a full service history and approx 180,000 miles. What do you guys think, you probably think I'm mad!
Post #370446 3rd Feb 2016 11:45pm
Road Stone
The turbo issue is expensive, because the advise is that you must change both at the same time.
I'm now at least, comfortable I'll not have this issue whilst I own this car, especially in remote locations!
Lots of other stuff to worry about!!
Cheers, Jerry
Post #370458 4th Feb 2016 5:14am
Zigzagsky
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Stick it on a diagnostic tool and you should get an idea what the issue is since going into limp mode will generate an error code.
Should point you in the the right general direction. 2005 Range Rover L322 TD6
2009 Jaguar XK 5.0 Portfolio
1969 Jaguar E Type Series 2, 2 Plus 2
Post #370711 5th Feb 2016 12:48pm
limp home mode could be being caused by the rather notorious split turbo hose.
As you are looking under the bonnet of the car it tends to be the hose on the right which splits under the webbing at the back end of it, where it bends to go into the throttle body. 5 mins to change with a screwdriver or small spanner and can be replaced with silicone hoses for more durability, but TBH the originals are not a bad price and tend to last a good few years.
see here on how to check and lash up temporarily. best to remove from the car to check properly.
http://www.fullfatrr.com/forum/topic26843.html There is nothing that can't be fixed with a hammer😜😜
Post #370782 5th Feb 2016 7:52pm
Page 1 of 3 123>
