Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 1 of 38 123 ... 363738>
As some of you may have read? The 4.4TDV8 engine seems to suffer with a catastrophic oil leak from the rear of the �V� leading to oil running down the bell housing, covering everything!!! Then runs onto the exhaust and stinks!
I have done almost every 4.4TDV8 we have seen so....... This appears to be a common issue!
So i did my own this weekend, which was NOT leaking much... But i knew it would develop if left.
First, remove the air box that houses the pollen filter, 2x 13mm headed nuts then pull the whole assembly off.
Next, remove the engine cover, simply pull it upwards and off.
The first two pics show the pipe with the 8mm headed bolt holding it in place.
Here is the pipe removed, Showing the two �flattened� rubber �O ring�s�
Here are the �O ring�s� removed and a simple �O ring� kit, available from fleabayetc etc...
And finally after replacement �O ring�s� fitted and the pipe refitted.
The car was then test driven, the mirror was then used to re-check there was no more leak Thumbs Up
Consider, my car has only covered 23k miles so worth looking whatever your milage is Thumbs Up
Post #369971 1st Feb 2016 8:26pm
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
Thank you! Now I just need to find a 4.4 TDV8 and try it on Thumbs Up Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #369979 1st Feb 2016 9:12pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
Thanks Craig, will be done next service. Just need to spec this work as extra Smile
Any idea of somebody making "proper" silocone turbo hoses instead of the crap ones?
Regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #369986 1st Feb 2016 9:42pm
There's an excuse to get oily this weekend. I will get the boroscope on mine at the weekend. I'm sure I have a couple of boxes of o rings in the garage somewhere!
Think I can figure where it is from the pics, take it you are looking back RHS when facing the car. There is nothing that can't be fixed with a hammer😜😜
Post #370011 1st Feb 2016 11:52pm
No no, bang on central NMJ... You will clearly see the lag'd pipe on the back, then look for the Ali pipe and follow it sir Thumbs Up
Easy to work with a small mirror as I did... A boriscope will be too close I think (certainly was with ours) Thumbs Up
Post #370014 2nd Feb 2016 12:16am
Thumbs Up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #370045 2nd Feb 2016 9:54am
don't think mine is leaking yet! There is nothing that can't be fixed with a hammer😜😜
Post #370125 2nd Feb 2016 9:33pm
Glad to see it Thumbs Up
Post #370177 2nd Feb 2016 11:34pm
CS
Thanks for this useful post. As a matter of interest, could one check for such a leak from underneath the car as an alternative to removing the pollen filter housing etc (assuming nothing dripping on the ground and oil level normal)? Only Range Rovers since 1988
Post #370390 3rd Feb 2016 9:12pm
It is really tricky to see from underneath, as it is at the top of the engine. I used a boroscope to look down the back of the engine.i would think you would need to take off the pollen filter housing to get a mirror into position. There is nothing that can't be fixed with a hammer😜😜
Post #370421 3rd Feb 2016 10:51pm
The normal give away is the smell of burning oil on a long run, then you put it on a rang and OH Censored !!! CS... Thumbs Up
Post #370422 3rd Feb 2016 10:51pm
GraemeS
Australia
Thanks Craig - I have no reason to suspect that mine wont leak in due course. Do you know the O-ring size as I'll have to get them before starting but would rather not have to mail-order genuine spare parts.
Post #370450 4th Feb 2016 2:34am
Baltic Blue
Thanks Craig,pity you are not local to me or I would be your next customer.
Do you mind if I print out topic and show it to my MD next service (included in 2yr approved guarantee package)?
Post #370510 4th Feb 2016 12:46pm
GraemeS
Australia
The pollen filter is very simple and quick to remove, as is the engine cover, after which checking using a mirror is also quick and simple.
The pipe is the centre oil feed pipe and has been superseded, as has the original pipe for the 4.4 in the L405 and the o-rings don't appear to be available as spare parts. The seals may have been replaced with appropriate Viton versions leading to the new pipe part numbers. Replacing with general purpose o-rings is likely to be only a temporary fix.
Edit: Looking at standard O-ring sizes my guess they're either BS204 or BS205 - I can get Viton BS204 locally. However if metric size (most likely) then many size possibilities.
Post #370817 6th Feb 2016 4:29am
Graeme I�m sorry i don�t... How would one measure an �O ring�? i can happily take a measurement for you but am unsure what you want me to measure, and how? Bow down
Post #370828 6th Feb 2016 10:19am
