Home > Technical (L322) > Wipers, Again, I have a few qustions |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
My rain sensor wipers also occasionally sweep the screen once on startup, but rarely work after that, I have to switch to the OFF position then back to rain sensing again. Gremlin in my view. Hoping you get it sorted. .
4th Jan 2016 6:20pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
No box behind the battery We are talking Range Rover L322 Vogue Full Fat, and not the L320 Sport?
4th Jan 2016 11:04pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
It sounds like you phoned the service dept. You're often better phoning the parts dept. The parts dept job is to sell parts and they don't really care who to, the service dept's job is to sell workshop time - though some are more helpful than others. If it's a common failure item, you'll often find the parts guy knows the part number from memory. |
5th Jan 2016 5:20pm |
Right, there is not a panel, it's a black box with a clip on lid, that comes off towards the space that the battery takes up.
5th Jan 2016 10:43pm |
Richard Gravelle Member Since: 04 Jan 2016 Location: Hampshire Posts: 3 |
Thank you I will try this again.
6th Jan 2016 5:26pm |
I would talk to L/R parts, as they might have changed the setup, I can't see why they would, but it might be that they used the last few years of production as cross over builds and that they have more in common with the L405 than the L322 Yesterday I couldn't spell Engineer... Today I are one!
7th Jan 2016 4:08pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
It isn't behind the battery on my car either .
7th Jan 2016 7:12pm |
Where exactly is your battery? is it in front of you (driver) or the passenger? Only all the ffrr's 2002-2009 have the same relay listed, so they should be in the same place..... Yesterday I couldn't spell Engineer... Today I are one!
7th Jan 2016 11:37pm |
The brake servo and wiper motor is behind the driver , the battery is on the other side .
8th Jan 2016 12:50am |
Well your looking for a box that's 6"-7" High and 9"-10" wide, on the RHD cars it sits vertically behind the battery, on the right hand side of the car viewed from the grill looking at the windscreen, so it still might be on the drivers side, failing that it's behind the battery looking like part of the firewall Yesterday I couldn't spell Engineer... Today I are one!
8th Jan 2016 1:28am |
The brake servo is on the drivers side , so there won't be a remove able panel behind that !!!
8th Jan 2016 3:08am |
Here are a few pics .
8th Jan 2016 4:31am |
And here's a really bad pic of the same area on the passenger side , behind the battery .
8th Jan 2016 4:34am |
Here are some pics of what is inside the fuse compartment .
8th Jan 2016 4:37am |
