![]() | Home > Technical (L322) > Wipers, Again, I have a few qustions |
My rain sensor wipers also occasionally sweep the screen once on startup, but rarely work after that, I have to switch to the OFF position then back to rain sensing again. Gremlin in my view. Hoping you get it sorted. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It sounds like you phoned the service dept. You're often better phoning the parts dept. The parts dept job is to sell parts and they don't really care who to, the service dept's job is to sell workshop time - though some are more helpful than others. If it's a common failure item, you'll often find the parts guy knows the part number from memory. |
Right, there is not a panel, it's a black box with a clip on lid, that comes off towards the space that the battery takes up.
Richard Gravelle Member Since: 04 Jan 2016 Location: Hampshire Posts: 3 ![]() ![]() ![]() |
Thank you I will try this again.
I would talk to L/R parts, as they might have changed the setup, I can't see why they would, but it might be that they used the last few years of production as cross over builds and that they have more in common with the L405 than the L322 |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
It isn't behind the battery on my car either .
The brake servo and wiper motor is behind the driver , the battery is on the other side .
Well your looking for a box that's 6"-7" High and 9"-10" wide, on the RHD cars it sits vertically behind the battery, on the right hand side of the car viewed from the grill looking at the windscreen, so it still might be on the drivers side, failing that it's behind the battery looking like part of the firewall |
The brake servo is on the drivers side , so there won't be a remove able panel behind that !!!
Here are a few pics .
And here's a really bad pic of the same area on the passenger side , behind the battery .
Here are some pics of what is inside the fuse compartment .
