Home > Technical (L322) > Wipers, Again, I have a few qustions
Page 2 of 3 <123>
My rain sensor wipers also occasionally sweep the screen once on startup, but rarely work after that, I have to switch to the OFF position then back to rain sensing again. Gremlin in my view. Hoping you get it sorted. Confused .
Post #365272 4th Jan 2016 6:20pm
miggit
Shocked No box behind the battery Shocked We are talking Range Rover L322 Vogue Full Fat, and not the L320 Sport?
Only I'd be surprised if they changed it for the last few years of production, as this relay was used in the whole production run from 2002 to 2009. I don't have any knowledge of the later L322, but I'm sure that Craig or another will enlighten us Thumbs Up
It sounds to me as if you've changed the washer relays and not the wiper one, as the fault that your reporting is a classic dud relay symptom. Yesterday I couldn't spell Engineer... Today I are one!
Post #365317 4th Jan 2016 11:04pm
Richard Gravelle
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Thanks for your reply.
Yes Full Fat one - big boy one Smile
I though the same as you after reading all the info below in the posts. To the point I went and purchased the new brown relay and look the battery out to replace it - big lift Wink. once i had removed the battery there was no panel to remove and i could not find the relay location any where there (checked the pictures that have been posted on this page to cross check and nope not the same).
Spend ages looking for where the relay would have been relocated wasn't in hand book and found it under bonnet drivers side (RHD). what found it/there they where replaced with a revised version smaller and two of them. I then phoned Land Rover and asked about issue they where no help and said they also where unable to supply me the relay (just bring the car in........).
Phone Keith Gott Land Rover and they had the Relays I needed. get them replaced them and again hummmm no go.
I have booked the car in for next week Thursday 14h as soonest i could get a Land Rover specialist to see it but can use it till then as all this rain - love to fix it my self too.
thanks again all
Post #365359 5th Jan 2016 10:17am
Zirconblue
It sounds like you phoned the service dept. You're often better phoning the parts dept. The parts dept job is to sell parts and they don't really care who to, the service dept's job is to sell workshop time - though some are more helpful than others.
If it's a common failure item, you'll often find the parts guy knows the part number from memory.
Post #365450 5th Jan 2016 5:20pm
miggit
Right, there is not a panel, it's a black box with a clip on lid, that comes off towards the space that the battery takes up.
Removing the battery, not too bad if the bonnet / hood (if your the wrong side of the pond) is in the service position.
To do this you need to lift the small metal clip on the cap of the gas strut that supports the bonnet and pop it off, then do the same again, either propping the bonnet or getting a helper, otherwise you may get a headache Shocked Lift the bonnet vertical and secure with the metal tab that is on the hinge, it slides a bit and you can pop it over the stud on the other part of the hinge.
Also put the car into low / access height, every inch counts Thumbs Up
But before I did any of that I would talk to the local L/R parts department and check that the relay is the correct one Thumbs Up
FYI the relay is under the windscreen behind the battery, not underneath the battery Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #365540 5th Jan 2016 10:43pm
Richard Gravelle
Thank you I will try this again.
One quick question - what are the two front wiper relays for in the relay/fuse compartments under the bonnet?
Surely there are not three of them?
I do wonder if their was a change made in the 2010 last face lift model?
Post #365696 6th Jan 2016 5:26pm
miggit
I would talk to L/R parts, as they might have changed the setup, I can't see why they would, but it might be that they used the last few years of production as cross over builds and that they have more in common with the L405 than the L322 Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #365875 7th Jan 2016 4:08pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
It isn't behind the battery on my car either .
2007 LHD .
I've not looked for it , but I was sound deadening that area last week
Post #365920 7th Jan 2016 7:12pm
miggit
Shocked Where exactly is your battery? is it in front of you (driver) or the passenger? Only all the ffrr's 2002-2009 have the same relay listed, so they should be in the same place..... Yesterday I couldn't spell Engineer... Today I are one!
Post #365972 7th Jan 2016 11:37pm
Ian c2
The brake servo and wiper motor is behind the driver , the battery is on the other side .
I had a quick look at the drivers side for soundproofing but kind of got dismayed at the servo and all that stuff in my way Laughing and I didn't notice any relays in there .
I'll take a closer look later when she gets home in it .
If not tomorrow .
But I suspect mine too is in the engine fuse box compartment ....
Another discrepancy I noticed is that I don't have a battery+ terminal in the engine compartment either .
Though I have the - post .
Post #365973 8th Jan 2016 12:50am
miggit
Well your looking for a box that's 6"-7" High and 9"-10" wide, on the RHD cars it sits vertically behind the battery, on the right hand side of the car viewed from the grill looking at the windscreen, so it still might be on the drivers side, failing that it's behind the battery looking like part of the firewall Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #365982 8th Jan 2016 1:28am
Ian c2
The brake servo is on the drivers side , so there won't be a remove able panel behind that !!!
I'll go take a look on the passenger side but considering the wiring loom is totally different on a car with all the controls on a different side , I don't think it's too far fetched to believe it's in a totally different position even if the part numbers are the same .
Just like the steering wheel might be the same part number , but it sits on the left hand side of the vehicle in my car Laughing
Post #365983 8th Jan 2016 3:08am
Ian c2
Here are a few pics .
It's dark , so please excuse the quality .
I can take more tomorrow if needed .
Here is the drivers side .
You can see it's pretty well packed with the servo and wiper motor and linkage assembly .
It's hard to tell from the photos , but factory sound deadening carpet is booted on to the bulkhead .
I need to remove this to add extra sound deadening to the bulkhead before bolting the carpet back on ,
Post #365984 8th Jan 2016 4:31am
Ian c2
And here's a really bad pic of the same area on the passenger side , behind the battery .
This side to has factory carpet bolted direct to the metal bulkhead .
But on this side it was easy enough to remove the battery , battery tray , and carpet , then add sound deadening to the metal bulkhead before bolting it all back together
Post #365985 8th Jan 2016 4:34am
Ian c2
Here are some pics of what is inside the fuse compartment .
Post #365986 8th Jan 2016 4:37am
Page 2 of 3 <123>
