![]() | Home > Technical (L322) > Wipers, Again, I have a few qustions |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
i can answer this one,
Cheers Buddy, I knew you wouldn't let me down |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
You could always do what swmbo does. Have the wiper in the on position cause its raining, turn off car and leave said wipers wherever they park on the screen. Wait till it has 6 inches of snow on the screen then jump in car, turn ignition and voila, one f'''ed wiper motor |
Done the relay last month when this started, I can live with no auto wipers if I've got intermittent. But it could turn a bit nasty if the |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
Agreed it is a nuisance to be without wipers, I had some pretty heavy downpours without them too. That said I am used to motorcycling.
i wonder if its a dodgy wire in the stalk assembly Paul.... ... - .- -.
Stan, very much doubt that, cos the washers were still working, all be it without any movement from the wipers |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Auto wipers are too erratic at faster speed for me so I removed the rain sensor fuse to have intermittent wipers instead. |
Does that affect your auto headlamps Graeme? |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
I'm pretty certain it's the wiper relay that is your problem.
Richard Gravelle Member Since: 04 Jan 2016 Location: Hampshire Posts: 3 ![]() ![]() ![]() |
Hi There,
