Home > Technical (L322) > Battery drain......sad face |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 |
4th Dec 2015 11:34am |
Due to not being able to do the red light check on the sat nav can anyone tell which fuse it is? I downloaded the PDF for the guide but I can't see which is for the sat nav or is that because it's not on its own and is with other items?
4th Dec 2015 5:16pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Haven't read the entire thread but what year and model is it as if you have headlight wipers these can fail to home properly and drain the battery |
5th Dec 2015 2:03am |
Range Rover Vogue HSE 2006. No headlight wipers on my car thou.
5th Dec 2015 8:27am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Does your sat nav work?? and your confusing me, it's EITHER an HSE or a Vogue.. if it's a Vogue it should have wipers, you say it hasn't, if it's an HSE it shouldn't have sat nav....!!! maybe it's an HSE with extras... does it have a heated steering wheel and REAR heated seats???
5th Dec 2015 1:51pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
If its on 05 /55 (6A) it will have no wipers and a touch screen (like mine) it's on the cross over
5th Dec 2015 1:54pm |
Oh yeah... doh.... still can't be an HSE Vogue though.... Pete
5th Dec 2015 2:01pm |
***update***
5th Dec 2015 3:56pm |
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 |
I had exactly this. Battery went from full to flat in about three days. Car electrician found the electric cooling fan had got a dead short. Fan replaced and all is well. |
5th Dec 2015 8:04pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
rangeseb, don't worry about not having headlamp wipers, when LR did the face lift in 2005 they ditched the wipers and went for a jet wash system instead Yesterday I couldn't spell Engineer... Today I are one!
5th Dec 2015 11:44pm |
Miggit.....
6th Dec 2015 12:40am |
It could be any number of things, you do know that there are 3 fuses for the nav computer? My nav head was going in to one the other day so I pulled the disc to stop it constantly trying to load it, clunk whirr all the time from the back, was driving me nuts! A pal of mine has had trouble with his FBH (Aux Heater) it keeps on trying to kick in, hours after the car has "gone to sleep". I don't believe that they go to sleep, I think that they just lay dormant waiting for the best time to strike Yesterday I couldn't spell Engineer... Today I are one!
6th Dec 2015 1:17am |
***update***
6th Dec 2015 9:38am |
***update***
6th Dec 2015 10:59pm |
