Home > Technical (L322) > Battery drain......sad face |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
So what is the voltage at the battery terminals with the engine off?
3rd Jan 2016 11:04am |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 |
I'm just off that after almost a month the problem is now maybe back. The fact it wasn't driven for 1 day yesterday then it's a non starter this morning is odd.
3rd Jan 2016 11:38am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Do you try and give it a few starts or just the one turn of the key ?
3rd Jan 2016 4:23pm |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Starter motor? Not my RR but I had those symptoms with my 911, did the whole lot myself before the garage replaced the starter motor.. |
3rd Jan 2016 4:37pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8499 |
a click could be the solenoid failing to engage on the starter, however given that it started off a jump then that is less likely, however it may have needed just that little bit more to make it engage. There is nothing that can't be fixed with a hammer😜😜
3rd Jan 2016 5:09pm |
True, however mine also would start from a power booster, the extra ommph probably engaged the solenoid |
3rd Jan 2016 6:07pm |
My bad! When I said clicking sound, I meant the sound you get when any car fails to turn over. It was the same sound I was getting back in Dec with with the battery drain problem.
3rd Jan 2016 7:27pm |
Also as I said before, since the new battery went in its been driven almost everyday even over X-Mass so maybe the new battery is holding charge and as it wasnt driven yesterday maybe it was too long for it to hold out?
3rd Jan 2016 7:31pm |
I still think you should get the starter checked, I took two batteries back before I took it into the garage |
3rd Jan 2016 7:38pm |
I will do.
3rd Jan 2016 7:40pm |
kaoleary Member Since: 14 Sep 2013 Location: Hertfordshire Posts: 26 |
I've got the same problem with my 2007 TDV8. It drains overnight but starts with a booster pack. After a couple miles there's enough charge to restart it, but left a few hours it'll drain again. I had a new starter motor 12 months ago and a big Bosch battery about 2 years back.
3rd Jan 2016 8:30pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
These are in your neck of the woods, L'R specialists rather than Auto Electricians, but I've only heard good things about them.
3rd Jan 2016 11:31pm |
Thanks.
4th Jan 2016 12:08am |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
If you want to fix it yourself , all you need is time , basic tools , and a multimeter ...
4th Jan 2016 4:40am |
