Home > Technical (L322) > Fuel type |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
In the uk, our 'regular' fuel, is 94 octane. We can get a premium 98 fuel here too.
13th Aug 2016 4:24pm |
Kinch Member Since: 08 Aug 2016 Location: Idaho Posts: 45 |
Wow! You have that high of an octane? Our max, at least where I live, is 91. I wonder if I could use Xylene to raise my octane. Xylene is pretty cheap. |
13th Aug 2016 9:02pm |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
We used to have BP Ultimate 102 at our local station but haven't seen it for a couple of years. Think the highest RON available here now is Shell V power 99
13th Aug 2016 9:29pm |
Does UK gasoline have any ethanol in it? |
13th Aug 2016 9:32pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Don't confuse US octane ratings with European ratings, they are measured differently.
13th Aug 2016 10:15pm |
Thanks for all that interesting information. What do you think about running non ethanol 89 Octane? I get better mpg with it in all my other vehicles. Thank you |
13th Aug 2016 10:32pm |
that explains to me! I thought it had to be similar. |
13th Aug 2016 11:08pm |
It's certainly worth trying if you find it's better than other types in your other motors.
13th Aug 2016 11:19pm |
You obviously know your stuff. How about this? Can't you raise the octane of gasoline with the common chemical xylol? Isn't that what petroleum companies use to raise octane? I read that somewhere. What if you raised the octane of your fuel using xylol? Is there a formula for that just curious. Not necessarily going to try it unless someone tells me it's common practice. |
13th Aug 2016 11:31pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
I think most of the world uses RON.
14th Aug 2016 12:50am |
I know a bit after researching info many years ago when running a high performance jap import that wouldn't run on anything else but high octane fuel but I'm certainly no expert.
14th Aug 2016 1:18am |
Yes I prefer to run non ethanol. My vehicles get better mpg but of course the non ethanol is slightly more expensive so I don't know if it evens out or not. Just thought maybe if I could not use 89 reliably, maybe I could boost it sufficiently and cheaply. Next time I need fuel I'll tank up with the non ethanol and see how it goes. |
14th Aug 2016 3:21am |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 383 |
I am in Sun Valley. I have a 2011 SC and only use 91 octane Non-ethanol. Its $3.29 here but car runs great. |
14th Aug 2016 3:31pm |
I would only use the 91 non ethanol not the 89 but that me. |
14th Aug 2016 3:34pm |
