![]() | Home > Maintenance & Mods (L322) > tdv8 battery |
monty1562 Member Since: 06 Jun 2014 Location: reading Posts: 10 ![]() ![]() ![]() |
hi guys, what are your thoughts on putting this battery in a 3.6 tdv8?
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I thought leisure batteries were for caravans etc? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
they work differently as well... ... - .- -.
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 ![]() ![]() ![]() |
have a look at Banner batteries, gsf car parts stock them |
I tried a deep cycle battery a few years back just as an experiment because I had a 110 ah kicking around , didn't work though and only lasted a year . They don't like the rapid drain of starting and take too long to charge up again so it was never getting a good charge and quickly failed . I have reconditioned it since then and it now sits in the man cave waiting for a job. 2008 MY Supercharged
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Interesting that that one does claim "1100 CCA".
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
If it helps I just had to replace mine, got a 100cca jobby by from Halfrauds with 5 year guaranty and a good brand "Yuasa" for �119.00 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
After replacing mine in the old tdv8 wth the Bosch S5 I am now leaning towards replacing the one in my 4.4 with a LR branded one.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Varta and Bosch are made in the same factory. |
^ yes they are, but the specs of the factory battery are different. Lower AH rating but higher Cca than most of the off the shelf batteries as far as I can remember |
Oh ok, what are the specs?
seem to remember it was
A couple of years back I bought a "Leisure Battery" and it has performed just fine. I definitely can start a TDV8 because I had it on one. It has sonce come with me through 2 5.0S/C models. No issues with the FBH, kids watching DVDs whilst I go in the shops etc.
On earlier cars Land Rover them selves offer an optional 110Ah battery, the 90Ah is the standard one. They didn't seem to offer it on the later models though, going by the parts catalogue. I suppose the newer generation entertainment systems are probably more efficient in terms of power consumption than the older ones. The catalogue does say the 110Ah option was only for cars up to 4A chassis numbers, but mine (with a 5A number) still came with the 110 from the factory. Would be interesting to see what the factory 110Ah ones kick out for CCA. |
