Home > Maintenance & Mods (L322) > tdv8 battery
monty1562
United Kingdom 2007 Range Rover Autobiography TDV8 Zermatt Silver
tdv8 battery
hi guys, what are your thoughts on putting this battery in a 3.6 tdv8?
http://www.ebay.co.uk/itm/12V-Xplorer-110A...Swv0tVJkaM
Post #353963 24th Oct 2015 3:20pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I thought leisure batteries were for caravans etc?
Post #353975 24th Oct 2015 6:24pm
they work differently as well... ... - .- -.
Post #353976 24th Oct 2015 6:26pm
n1cktdv8
Yes, they deep cycle...that won't have enough instant juice to kick a tdv8 over mate
You need something along the likes of Fiddler's Ferry or Sizewell Rolling with laughter Is this where I put the car details and a bit about myself ?........
Post #353977 24th Oct 2015 6:28pm
acrr1
United Kingdom 2002 Range Rover Vogue Td6 Oslo Blue
have a look at Banner batteries, gsf car parts stock them
Post #353979 24th Oct 2015 6:35pm
I tried a deep cycle battery a few years back just as an experiment because I had a 110 ah kicking around , didn't work though and only lasted a year . They don't like the rapid drain of starting and take too long to charge up again so it was never getting a good charge and quickly failed . I have reconditioned it since then and it now sits in the man cave waiting for a job. 2008 MY Supercharged
Post #354024 25th Oct 2015 9:57am
Lost for Words
Interesting that that one does claim "1100 CCA".
Arrow https://www.tayna.co.uk/EA1000-Exide-Premi...P7488.html Thumbs Up
(Use discout code "D2BOYS" for a few quid off. Wink ) Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #354323 27th Oct 2015 12:03pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
If it helps I just had to replace mine, got a 100cca jobby by from Halfrauds with 5 year guaranty and a good brand "Yuasa" for �119.00
Post #355345 4th Nov 2015 8:35pm
After replacing mine in the old tdv8 wth the Bosch S5 I am now leaning towards replacing the one in my 4.4 with a LR branded one.
The ones in the tdv8 are varta ones and the exact one isn't available over the counter at the likes of halfords, we are tending to make best guess replacements based on price. The spec of the LR branded battery nmatched to the demands of the car. No they don't last 10 years but failure can be hastened by alternator problems and they seemed to last longer than the Bosch ones There is nothing that can't be fixed with a hammer😜😜
Post #355348 4th Nov 2015 8:52pm
Zirconblue
Varta and Bosch are made in the same factory.
Post #355365 4th Nov 2015 10:17pm
^ yes they are, but the specs of the factory battery are different. Lower AH rating but higher Cca than most of the off the shelf batteries as far as I can remember Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #355367 4th Nov 2015 10:25pm
Zirconblue
Oh ok, what are the specs?
Obviously mine is an earlier car but when I looked at replacement there were two ah options. 95Ah or 110Ah. I didn't look at the cca but the Bosch I got is 110Ah. Mine had a 110Ah fitted at the factory (according to the build sheet) presumably it was fitted on the higher spec cars to cope with things like the park heater and tv.
Post #355378 4th Nov 2015 11:04pm
seem to remember it was
12v
950Amps SAE
90 AH
in my tdv8.
the S5 Bosch and Varta ones give 920A in the larger 020 size albeit with 110AH, the 019 sized ones which rate at 100ah only give 830A.
Though to some degree the figures given depend on the testing procedures they used for the CCA test. There is nothing that can't be fixed with a hammer😜😜
Post #355504 5th Nov 2015 6:42pm
mzplcg
A couple of years back I bought a "Leisure Battery" and it has performed just fine. I definitely can start a TDV8 because I had it on one. It has sonce come with me through 2 5.0S/C models. No issues with the FBH, kids watching DVDs whilst I go in the shops etc.
This one.
http://www.justcarbatteries.co.uk/index.ph...ttery.html
Post #355512 5th Nov 2015 7:36pm
Zirconblue
12v
950Amps SAE
90 AH
in my tdv8.
On earlier cars Land Rover them selves offer an optional 110Ah battery, the 90Ah is the standard one. They didn't seem to offer it on the later models though, going by the parts catalogue. I suppose the newer generation entertainment systems are probably more efficient in terms of power consumption than the older ones.
The catalogue does say the 110Ah option was only for cars up to 4A chassis numbers, but mine (with a 5A number) still came with the 110 from the factory. Would be interesting to see what the factory 110Ah ones kick out for CCA.
Post #355549 6th Nov 2015 12:29am
