Home > Maintenance & Mods (L322) > tdv8 battery
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I had a dealer battery as there spot on as much as i dislike stealers! one of the few items id buy as wih FBH spurious can play up even explode on some 170+vat cost the pics on my backposts of bill . _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #355556 6th Nov 2015 3:53am
mzplcg
Also worth remembering that LR did start fitting a AGM battery to later models with the FBH. It wasn't cheap though, somewhere in the region of 400 quid. That was why I bought the AGM one from Varta as they can stand a lot more of the load which takes place in winter.
All those CCA and AH figures are only relevant if the battery is in good condition and a regular lead/acid one will deteriorate rapidly with constantly being discharged beyond what a normal start takes out. AGM are designed for deep cycling so they stay in good condition for longer. Not only that, they still deliver full CCA when they're discharged as far down as 30% of capacity, i.e. you can still start the car when a lead/acid unit would be considered flat.
Post #355561 6th Nov 2015 8:30am
Weirdly the 110ah which can be specified in the earlier cars (ydg000271) has a lower CCA rating too at 850amps. Probably because it was designed to be used in the petrol V8 and td6, it is an 020 size battery so the physically same size as the Bosch and varta ones. There is nothing that can't be fixed with a hammer😜😜
Post #355650 7th Nov 2015 9:55am
