Home > Technical (L322) > Rear diff locked up 3.6TDV8? Problem.... |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
Good to know that. Still locked up when I left it but didn't go more than a few hundred yards slowly. Will try it more when I get it back.
19th Oct 2015 2:55pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I'm obviously a bit more devil may care, when mine did it I just booted it with a wheel locked up and stood on the brakes a few times till it sorted itself out.... just tell it who's boss.... Pete
19th Oct 2015 3:27pm |
Well slight update - after jumping in with one of the other more inexperienced guys as an instructor come guide he was leaving early so stayed the night at my parents. I then went and borrowed a trailer from a friend and returned to the pub to pick up the RR.
21st Oct 2015 10:06pm |
Small taster - hopefully you guys can see it but one of the guys posted it on his Facebook page.
21st Oct 2015 10:09pm |
Bet that took some paint of your towbar... certainly took some off my old bumper...!!!
21st Oct 2015 10:13pm |
Ironically (despite the sound) nothing touched on the bomb hole. Did hit the armature on Soar y Mynydd where they've been patching up the track though. Nothing bad at all, just a bit of dust. Ed |
21st Oct 2015 10:40pm |
Pete
21st Oct 2015 11:07pm |
Right some more (lack of) progress:
22nd Oct 2015 8:51pm |
Whats VDS ???
22nd Oct 2015 9:01pm |
Sorry VDM - Vehicle Dynamic Module.
22nd Oct 2015 9:27pm |
Does it still jerk when driving ??
22nd Oct 2015 9:36pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2471 |
For MY07-MY12 the suspension will always lower for any brake system fault, with the logic being to make the vehicle safer whilst there's a brake system fault. Hence the suspension fault can be ignored. |
23rd Oct 2015 7:04am |
Where is the TCCM mounted in these vehicles? The D3/D4's TCCM is mounted in the engine bay, is not sealed and fails if it gets wet. Its also a node in the canbus network so when it fails it effectively isolates the halves of the network making ecus on either side of it unable to communicate thereby causing a raft of faults.
23rd Oct 2015 7:14am |
Yes the drive does still yerk - took it for a spin in the field last night and got it up to about 30mph before running out of space and did that for a while and that didn't sort anything out.
23rd Oct 2015 8:10am |
