![]() | Home > Technical (L322) > Rear diff locked up 3.6TDV8? Problem.... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2636 ![]() ![]() |
Brake pad wear sensors only trigger the instrument warning and height sensors only connect to the suspension ecu and have no ability to cause brakes to be activated. |
Whilst moving? |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Yes - but only up to the limit of what I could do on the yard. Got up to 12kmph but all four were consistent. Ed |
(Edited my post) according to the workshop manual the TCCM is inside the big black box inside the engine bay and that shows no sign of water, if indeed that is the cause. The 4x4 info screen also shows that the central diff was unlocked - although now the fault is instantaneous I can't change the terrain response to a non-road one to see what it's saying. Ed |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1450 ![]() ![]() |
Going back to the start . . . you say that the inner rear wheel is skipping when turning. Can you be specific on this, when it does a skip is the rear wheel:
MY07 has electronic clutch in centre diff, not Torsen. TDV8 was introduced with MY07. |
I don't like the TCCM adaptive clutch as its limit fault but the hard-on ABS fault and the string of invalid bus data faults that could occur if no speed message is seen on the HS canbus suggests the ABS ecu is likely to be the primary cause.
Battery has been disconnected and I've clamped the two terminals together whilst I have lunch so we'll see. I have had the battery disconnected before for >10s but that hasn't changed anything. Just before lunch I got the multi-pin connector off the ABS module and that looks perfectly clean.
Well hopefully the car will be on the way to Craig tomorrow morning, I'm now 600 miles away up in the Highlands. I did check just before leaving and its exactly like the centre diff is locking up. Inside rear wheel tries to rotate faster than the surface. It looks like there's a solenoid that switches the motor over to change high / low and activate the centre diff. Maybe something to do with that. The hi / low change works fine but wasn't able to categorically find out about the centre diff. With all four wheels off the ground I was able to spin just one wheel, albeit with the engine off. Did not try turning the engine on. Ed |
Right - final update (hopefully).
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8507 ![]() ![]() ![]() |
Ed, did it need a new one or did an oil change sort it out... must be different from the earlier ones as mine has sat totally submersed in water on more than one occasion and never has any water at all in it.... Pete
It has just had an oil change and re-calibration.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
Craig guess it may have been condensation Ed! As that is what seems to occur in the rear diff of the 3.6 & SC constantly... Could just as easily be a leak and given this info...
Thanks for the clarification - I shall take a decent look this evening, hopefully... Ed |
