![]() | Home > Technical (L322) > Rear diff locked up 3.6TDV8? Problem.... |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
A valid coincidence with the tyres - they were fitted on the 24th of August. I suppose it is a possibility that the ECU is detecting the wheels have less traction and therefore partially locking up the LSD.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8507 ![]() ![]() ![]() |
Glad I've got the earlier FF then, what with less comfy seats, far more rust, diffs, and now transfer boxes filing with water the later ones seem to be a step backwards....
Ah the price of us being pioneers |
Maybe but I can't see it pulling in water even if the pipe had come off the breather and it was totally under water, the breather is (well should be) the only link to the outside world so water won't pour in, a very small amount may find it's way in but not enough to do much...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
Which leads us back to long term condensation Pete???
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
I had those exact warning lights in that sequence, it was an abs sensor Many thanks Paul |
I agree Craig but I think there are two things going on... can't see the centre diff making the inside rear wheel skip, it would make the easiest one, the outside one, skip.... I still recon it's an ABS sensor giving faulty signals to the ECU and it's trying to lock a wheel as it thinks it's spinning, mine did the exact same thing and now Pvw10 says his did the same I'd be inclined to check them... Can you get live date from them individually on yours, I don't think the earlier ones can... mine was the nearside rear and that one does the speedo so I had a good indication of it's erratic nature by loosing the speedo and variable rate power steering... as you don't have these faults as well then I recon it's the off side rear sensor... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Pete, with all due respect my friend, the car was driving fine when returned! The centre diff oil was badly contaminated with water!
Pete,
Sorry, read it wrong, thought it was still a problem... yep, I suppose water in the diffs and tranny box can do all sorts of things, If it's just doing it a tad then a good flush out will hopefully sort it.... I left the tide mark just above the door pocket on mine to remind me not to go swimming.... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2636 ![]() ![]() |
Applying a vacuum/low pressure to a diff or TC is exactly the opposite to what is required to keep water out when submerged. Cooling of a diff or TC housing whilst submerged causes water to be sucked in past seals as the inside pressure lowers. Don't enter deep water with hot transmission components! |
I meant to keep condensation out, change the air in there all the time and it should work... works to keep it out of distributor caps...
Well changed the oil in the transfer box this evening and it was pretty dire. Tiny metal particles in there as well by the looks of it. Might do another change in a few weeks to see how it looks.
Hope it's OK.... |
