Home > Maintenance & Mods (L322) > Front and Rear Winch bumpers and swing away wheel carrier..
Page 4 of 5 <12345>
No excuse for getting stuck now Thumbs Up top skills. There is nothing that can't be fixed with a hammer😜😜
Post #348234 17th Sep 2015 6:54pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
TOP JOB Thumbs Up Thumbs Up Thumbs Up
Post #348242 17th Sep 2015 7:34pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Cracking job Pete - very neat Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #348248 17th Sep 2015 7:43pm
Thumbs Up Thumbs Up Thumbs Up Bow down
Post #348249 17th Sep 2015 7:46pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
very smart job! You could sell those!! Bow down
Post #348253 17th Sep 2015 8:09pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Nice work I know thing I wouldn't want to run into the back of you I would imagine it kill any car instantly L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #348271 17th Sep 2015 10:15pm
miggit
I think I know where he got his styling ques from, I stumbled on this earlier
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #348281 17th Sep 2015 10:58pm
Thanks chaps...
Mike, had both in the past, I know plasma is supposed to be a better bet but personally I don't like it, it doesn't last long, it's not UV stable no matter what they claim and it jams on the drum easily as it pulls through the layers... I can see it's appeal if your doing challenge events but IMHO for every day laning wire rope is far more suitable...
There have also been several cases of anti's cutting up peoples plasma rope... bit difficult with a wire one.... Thumbs Up
Stan, sad, but I really like the early grille and lights, to me it just looks right for an FF so I'll keep this one, you don't generally get too much in the grille so it should be OK... Thumbs Up
Sam, don't think we would sell many, we worked out they would be about £750 each to make as they would have to be custom fit unless you got orders for loads and could go to the expense of making jigs for them...
Paul, please!!! that bumper looks awful... just flat plate and a daft "A" bar Pete
Post #348284 17th Sep 2015 11:16pm
chaybra
Australia 2006 Range Rover Vogue Td6 Zambezi Silver
Great to see some serious stuff being done! Finally!
I am presuming there is no issue with Air bag compliance over there? That is what is hindering my efforts here down under Sad
Post #348307 18th Sep 2015 1:11am
miggit
Pete, just had a thought, Shocked , you should change the description of your ffrr to " 2002 Range Rover Vogue 4.4 V8 Epsom Green Up Armored Northern England Spec. " Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #348409 18th Sep 2015 4:03pm
Chaybra , No, no silly airbag stuff here, can't see a front bumper can make any difference to a decelerometer that isn't fixed anywhere near it anyway...!!!
Paul, you should get out more....!!! Pete
Post #348460 18th Sep 2015 10:13pm
sako243
Pete,
Any chance you took some more piccies of the front bumper internals? I'm toying with building a winch mount myself but think I might get away with concealing it behind the plastic bumper... It'll be tight be looks feasible.
If you don't then no worries. Ed
Post #350122 30th Sep 2015 10:09pm
Should be enough room, my new bumper doesn't protrude forward any further than the original, just replace the metal under bumper (for want of a better word) with a fabricated box section to house the winch, if you remove the aircon rad it would give you a bit more room... lower bumper skin mounts could still be used, you'd have to fabricate some different top mounts for the skin but it shouldn't be too hard... you would have to cut out the rear of the bumper skin but it looks doable, you might lose the central two PDC sensors...
Do you want pictures of the original bumper internals or the new one?? Pete
Post #350135 30th Sep 2015 11:17pm
sako243
The new one ideally - I'm just after ideas more than anything else, I'm familiar with the structure behind the bumper. The challenge, which I've accepted, is to leave things as functional as they were before. The winch I have (TDS Goldfish) looks like once the solenoids are relocated will bit between the PDC sensors. Similarly looks like there might be just enough room to fit it infront of the air-con radiator...
I'm also curious from all the tales of your de-silenced exhaust what it sounds like now Thumbs Up Ed
Post #350151 1st Oct 2015 7:10am
Don't under any circumstances remove the back box, it is ridiculously loud, makes your ears bleed, children run away screaming, car alarms go off.... etc etc it really is far too loud to leave like it is I have several ideas to reduce the noise to an acceptable level...
But it does sound wonderful, rather like an American NASCAR...
Haven't really got an other pics of the bumper, the pics on page 2 give the best idea, the front of the bumper is welded to the front of the winch tray and the top goes just under the headlights... not really much else to see..
That set up on page 2 would fit behind the original bumper but you would have to fix the bumper some different way and remove a lot of the foam and plastic from the back of it...
Thumbs Up Thumbs Up Pete
Post #350237 1st Oct 2015 8:08pm
Page 4 of 5 <12345>
