![]() | Home > Maintenance & Mods (L322) > Front and Rear Winch bumpers and swing away wheel carrier.. |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
TOP JOB |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Cracking job Pete - very neat Howard
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 ![]() ![]() ![]() |
very smart job! You could sell those!! |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
Nice work I know thing I wouldn't want to run into the back of you I would imagine it kill any car instantly L322 2008 vogue
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I think I know where he got his styling ques from, I stumbled on this earlier
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Thanks chaps...
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
Great to see some serious stuff being done! Finally!
Pete, just had a thought, |
Chaybra , No, no silly airbag stuff here, can't see a front bumper can make any difference to a decelerometer that isn't fixed anywhere near it anyway...!!!
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
Pete,
Should be enough room, my new bumper doesn't protrude forward any further than the original, just replace the metal under bumper (for want of a better word) with a fabricated box section to house the winch, if you remove the aircon rad it would give you a bit more room... lower bumper skin mounts could still be used, you'd have to fabricate some different top mounts for the skin but it shouldn't be too hard... you would have to cut out the rear of the bumper skin but it looks doable, you might lose the central two PDC sensors...
The new one ideally - I'm just after ideas more than anything else, I'm familiar with the structure behind the bumper. The challenge, which I've accepted, is to leave things as functional as they were before. The winch I have (TDS Goldfish) looks like once the solenoids are relocated will bit between the PDC sensors. Similarly looks like there might be just enough room to fit it infront of the air-con radiator...
Don't under any circumstances remove the back box, it is ridiculously loud, makes your ears bleed, children run away screaming, car alarms go off.... etc etc it really is far too loud to leave like it is I have several ideas to reduce the noise to an acceptable level...
