![]() | Home > Maintenance & Mods (L322) > Front and Rear Winch bumpers and swing away wheel carrier.. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
Right that's it, your off my Christmas card list.... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7898 ![]() ![]() ![]() |
You need one of those bumper stickers I saw on a Defender once - "Your Skid Stops Here"
Last few bits of welding finished, bent up some recovery points out of 18mm bar, cut holes in the front face of the bumper, welded them through and onto a piece of 8mm plate welded to the rear 8mm plate (should be able to pull just about anything with them |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
from someone that has done a far bit of fabrication in the past, that is one nice looking bumper
Wow. Can't believe how different it looks when painted.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Looks even better in the flesh mate...nice job |
Cheers chaps, had a look at the front today, plenty of room for the winch once all the superficial plastic removed and the air con fan, don't need it any more since fitting the electric fans to the other side of the rad... It won't stick out any further than the original bumper...
Also got the rear winch sorted, picked up a broken old one, stripped it down, fixed it and repainted it, should be OK for a while... Pete
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
That is one bit of kit now |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
Pete your a very bad man |
Mr G... probably getting close... I wouldn't want it blowing away you know... |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Hi Pete - as ever most interested in your posts - keep up the good work - brilliant job with the bumper. Howard
Cheers SMUTT
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
Looks great, fantastic fabrication, one mean Range Rover! Regards
