Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android
Page 24 of 36 <123 ... 232425 ... 343536>
Haven't used mine but it will be either 12v or earth....
The pink wire could be a reverse wire for the satnav... if that doesn't work there is the black wire with the RCA plugs that is a camera earth, maybe it switches the camera on....
If not, send an email to Erisin... Pete
Post #334879 28th Jun 2015 2:31pm
L322inOz
Australia
Cheers Pete....
See how it goes tomorrow.
Fingers crossed.
Post #334881 28th Jun 2015 2:45pm
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Hi all. I have made the decision to get one of these units. Hopefully will be buying it tomorrow. Could really do with a little bit more advice first please?
Is this the correct one? Item number eBay Item No. 131231887218 on eBay?
Plus I need a long aerial lead?
Plus a dtv box for TV on go?
And this looks like you have a USB lead coming around from the back of the unit?
And with mine being a hse but with sat nav screen it should be just plug and play?
Thanks in advance. 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #337265 13th Jul 2015 7:45pm
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
tried to read through all this
im going to email crystal to order, ask for the extension 40pin cable but...i have DSP and AMP and am wondering is it plug and play, ie is the dsp and amp still going to be plugged in to power the speakers as i dont want the headunit running the speakers or to be cutting into the speaker wires really?
thanks
Post #338748 23rd Jul 2015 8:31pm
mjdronfield
What you mention above is the best route to get the best sound from the system, by feeding pre amp from the android head unit into the bm54 that's there now and that will feed dsp and thus speakers in an active manner......
Trouble is, nobody has tried to do it that way yet....... Pete and the others chopped into the speaker wires and drive many speakers from a single channel. Sacrificing sound quality for an easier install. Though to be fair, it's the only tested route so far......
Plus if you go your suggested route, you will still have the sub woofer working.....
How you feed to the bm54 (amp) by pretending to be an existing source has yet to be tested......
Let us all know.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #338749 23rd Jul 2015 8:39pm
wedgel322
Hi all. Mine came yesterday. Got the head unit, digital TV box, rear camera, and the extension lead all for £326 from crystal. Going to fit it in a couple of weeks. 2003 Range Rover HSE 3.0 TD6
Post #338750 23rd Jul 2015 8:40pm
mjdronfield
I see yours is a 2005....... Take it it's not touchscreen..... ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #338752 23rd Jul 2015 8:41pm
Ohwhatalad
mine isnt no its a 54 plate 2005, non touch screen.
its a real shame and the only thing holding me off doing it, cant justify taking out amp and dsp for an inferior sounding 50wchannel amp built into the head unit itself.
i see there is an option to add RCA out to the BM54 via the guy who does the BM54 modding/upgrade.
i wonder if he knows how to add RCA input, surely then could use an RCA cable from headunit into the BM54 to give all speakers power.
lots of thinking to be done to see if this is viable, really want the nice screen and nav up front!
Post #338754 23rd Jul 2015 8:46pm
mjdronfield
Good idea that man !
As someone who has had the bm54 stage 2 amp upgrade done by Baris on here, I can say it sounds much much better. Well loud and clear. Baris can add an aux input with rca as you say, which the android head unit can plug into to feed the existing system.
I'd give him a call or send him a PM and see what he suggests. You don't have to have the amp itself upgraded of course, but I would if he's adding rca's anyway.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #338755 23rd Jul 2015 9:02pm
The problem is switching the DSP amp on.... it's controlled by a canbus signal from the old head unit... some have put the old head unit in the glovebox (it fits where the CD player is) to turn it on but I haven't tried this as all my boot stuff was knackered after drowning in a Welsh river... can't see why it won't work but I bet it's still not plug and play...
There must be someone somewhere who could make a little box to turn the amp on, like the one that comes with this unit to do the steering wheel buttons... I did suggest this to Crystal but her English, although much better than my Chinese, is not good and I don't think she understood it....
Marks upgraded system does sound superb, this system does sound on par with the original, a friend of mine who has HD ears, he's a musician of high regard recons my set up actually sounds better than the Logic7 system in a mates TDV8, said something about the separation was better....!!! Pete
Post #338777 23rd Jul 2015 10:42pm
MrKev
Can I question that? I was all up for building a CAN interface to control this, but can't find the CAN signals to the box. I'm referring to http://workshop-manuals.com/landrover/l322.../page_751/ for reference. Am I looking a the wrong thing - I'm still trying to find may way round the L322 documentation.
It looks like pin 10 of the DSP amp is 'radio on' signal - is that not just an on/off signal then?
Kev
Post #343982 23rd Aug 2015 7:26pm
mjdronfield
That's not the dsp amp. That's the amp in the middle spec option.
Dsp page
Looks like pin 4. I imagine the bm54 radio module, which contains the amp and feeds 4 channels to the dsp will have same.
This is the bit that nobody has tried to do / tested. I understand the dsp has to identify itself on the ibus for the bm54 to realise it's there. It then operates slightly differently I am told. The sources will also have to identify themselves on the ibus to be available as a source, if you could get the bm54 to turn on without the screen fitted, you'd need to feed the android head unit into a source at line level and then get the bm54 to think the source is there on the ibus.
If we disregard the bm54 and just feed the androids 4 channels into the dsp, it may work, but it's never been tried. The radio on signal would need to be looked at using a volt meter if it's simply 12v. I'm wondering if it's not really an ibus connection though.
We need more testing in this area...... It's from what we can see on the BMW forums etc from others that have tried. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #343996 23rd Aug 2015 7:59pm
mjdronfield
A bit more info here ?
Mentions a "stay alive" signal..... Or the amp powers off again.
http://forum.bmw5.co.uk/topic/31017-bypassing-bm54-audio/ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #344006 23rd Aug 2015 8:19pm
Well done Mark, you put it so much better than me... all I know is "It don't work mister" Rolling with laughter Rolling with laughter Pete
Post #344041 23rd Aug 2015 11:51pm
jeff64
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
HI everyone, been following this thread for a while now but sorry to say it all goes straight over my head,saying i know nowt about electrics is an understatement,anyway i have a 2004 td6 hse with just the radio/cd which has a DSP amp.My question is can this android unit be fitted,hope someone can tell me if its possible. thanks JEFF
Post #345052 29th Aug 2015 8:19pm
