Home > General > How much snow (or flooded roads) is too much?
JAYBOY
I did one last week.
great day out Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #298437 11th Dec 2014 8:26pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
likewise, in fact i did 6 sessions.... Shocked Cheers
James
Post #298438 11th Dec 2014 8:27pm
RR2008HSE
How much snow is too much?
Okay, I've done winter offroading in Canada. Snow is usually the biggest barrier there is. When the snow gets deep enough that the car starts to try and push it, rather than drive over it, then forward progress will stop pretty quickly. Snow is heavy and, while you may be able to push through a drift, you can only do it for a very limited distance. So, look at your ground clearance. That's maximum.
I remember encountering deep snow with a friend's D2. He had VERY aggressive tyres AND snow chains. We were on a step downhill section. It took an hour with the winch to get him out. Also, snow can easily cover and hide many things you do not want to drive over. Careful.
Post #298534 12th Dec 2014 9:34am
Dolphinboy
it's too much when you need a lot of these to get out!!
http://tinyurl.com/no5ppjd
Post #298565 12th Dec 2014 12:54pm
steptoe
Re: How much snow (or flooded roads) is too much?
Brian wrote:
Silly question I suppose but as a complete novice to 4x4's let alone driving one I was wondering (as the title suggests) just how much snow can a standard unmodified (with normal road wheels and tyres) withstand?
Just because it's a 4x4 doesn't mean you'll have more grip in the snow... you'll have more traction, but that's different to grip.
In snow with normal tyres on your 4x4 you'll have the same amount of grip as a car with normal tyres.
But your 4x4 will take you longer to stop due to the weight and be heavier when cornering so more likely to slide off the road.
Hence why every winter when it snows for the first time car forums are full of pictures showing 4x4's in ditches. Mr. Green
And turn off traction control and ABS in snow if your vehicle has such a function.
Post #298827 13th Dec 2014 8:42pm
RR2008HSE
^Re ABS
In DEEP snow, yes. Locking the tyres will cause them to snowplough and stop quicker than with ABS (but with less directional control). With packed snow, or small accumulations, I'd keep the ABS on.
Can we even turn ABS off in the FFRR. I've never tried.
Post #298850 13th Dec 2014 10:33pm
T24RES
This is a film clip in a post from a previous year, i guess you could say this is about as much water as you'd need Rolling with laughter
http://www.youtube.com/watch?v=9XYdeZMSbjE Ian
Post #298898 14th Dec 2014 12:09pm
Not strictly true, as most Range Rovers (if not all) have M&S tyres fitted from factory! Passenger cars do not!!!
Post #298903 14th Dec 2014 12:18pm
Brian
I think there is a trick you can use to temporarily disable the abs (something about pumping the brake pedal) but it comes back on again at a certain speed but I won't be doing that Shocked What little snow we get here is already heading off and its rare we get anything more than 3 or 4 inches anyway - we do get a lot of floods though so that was more important and again don't often see anything more than a few inches to maybe 2 feet. If we get a lot of snow I'll consider buying a spare set of wheels with winter tyres on them (not fancy alloys just whatever passes as bog standard for one of these) but I'm broke after spending all my money on the car and will have to save up my penny's Cool
Post #298904 14th Dec 2014 12:19pm
steptoe
I do say "in the snow with NORMAL tyres on your 4x4" Mr. Green
Post #299312 16th Dec 2014 4:00pm
Custom10
Norway 2014 Range Rover Autobiography TDV6 Santorini Black
Here is my former P38 in the snow. It gives an idea on how much it can handle.
Great fun it was..
The toyota belongs to my mate.
Post #299340 16th Dec 2014 6:28pm
bebechoon
France
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #299712 18th Dec 2014 7:57pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
cruise control in snow....that i dont do
but i do use cruise control in FOG
my theory is that with max distance set, and doing say 40 mph....if i see something stopped first, i can override the cruise control by application of the brakes. If the radar sees something first before me stopped up in the fog on the motorway it will apply brakes first.
or alternatively....
its very difficult on some cars to tell fog lights and brake lights apart. radar might realise car in front is braking before you do.....
Post #300550 23rd Dec 2014 9:36am
RR2008HSE
Smart idea, Rambles. I've never had the radar cruise, so I've never thought about it, but that makes sense.
Post #300662 23rd Dec 2014 10:01pm
fisha
On the flooded road aspect, as a basic rule of thumb I gauged the rough safe depth as the top of the alloy wheel rim. Not the top of the tyre rubber, but the rim. That way it was simple to stck your head out the window and edge into water watching the water against the wheel.
There is more to wading than just that ( such as creating bow waves etc) but it's a good start V8 or else ...
Post #301182 27th Dec 2014 8:57pm
