Home > General > How much snow (or flooded roads) is too much? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
I did one last week.
11th Dec 2014 7:26pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
likewise, in fact i did 6 sessions.... Cheers
11th Dec 2014 7:27pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3166 |
it's too much when you need a lot of these to get out!!
12th Dec 2014 11:54am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Just because it's a 4x4 doesn't mean you'll have more grip in the snow... you'll have more traction, but that's different to grip. In snow with normal tyres on your 4x4 you'll have the same amount of grip as a car with normal tyres. But your 4x4 will take you longer to stop due to the weight and be heavier when cornering so more likely to slide off the road. Hence why every winter when it snows for the first time car forums are full of pictures showing 4x4's in ditches. And turn off traction control and ABS in snow if your vehicle has such a function. |
13th Dec 2014 7:42pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
^Re ABS
13th Dec 2014 9:33pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
This is a film clip in a post from a previous year, i guess you could say this is about as much water as you'd need
14th Dec 2014 11:09am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Not strictly true, as most Range Rovers (if not all) have M&S tyres fitted from factory! Passenger cars do not!!! |
14th Dec 2014 11:18am |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
I think there is a trick you can use to temporarily disable the abs (something about pumping the brake pedal) but it comes back on again at a certain speed but I won't be doing that What little snow we get here is already heading off and its rare we get anything more than 3 or 4 inches anyway - we do get a lot of floods though so that was more important and again don't often see anything more than a few inches to maybe 2 feet. If we get a lot of snow I'll consider buying a spare set of wheels with winter tyres on them (not fancy alloys just whatever passes as bog standard for one of these) but I'm broke after spending all my money on the car and will have to save up my penny's |
14th Dec 2014 11:19am |
I do say "in the snow with NORMAL tyres on your 4x4" |
16th Dec 2014 3:00pm |
Custom10 Member Since: 24 Jul 2014 Location: Asker Posts: 12 |
16th Dec 2014 5:28pm |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
18th Dec 2014 6:57pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
cruise control in snow....that i dont do
23rd Dec 2014 8:36am |
Smart idea, Rambles. I've never had the radar cruise, so I've never thought about it, but that makes sense. |
23rd Dec 2014 9:01pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1378 |
On the flooded road aspect, as a basic rule of thumb I gauged the rough safe depth as the top of the alloy wheel rim. Not the top of the tyre rubber, but the rim. That way it was simple to stck your head out the window and edge into water watching the water against the wheel.
27th Dec 2014 7:57pm |
