![]() | Home > General > How much snow (or flooded roads) is too much? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I did one last week.
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
likewise, in fact i did 6 sessions.... |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
it's too much when you need a lot of these to get out!!
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Just because it's a 4x4 doesn't mean you'll have more grip in the snow... you'll have more traction, but that's different to grip. In snow with normal tyres on your 4x4 you'll have the same amount of grip as a car with normal tyres. But your 4x4 will take you longer to stop due to the weight and be heavier when cornering so more likely to slide off the road. Hence why every winter when it snows for the first time car forums are full of pictures showing 4x4's in ditches. ![]() And turn off traction control and ABS in snow if your vehicle has such a function. |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
^Re ABS
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
This is a film clip in a post from a previous year, i guess you could say this is about as much water as you'd need |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Not strictly true, as most Range Rovers (if not all) have M&S tyres fitted from factory! Passenger cars do not!!! |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
I think there is a trick you can use to temporarily disable the abs (something about pumping the brake pedal) but it comes back on again at a certain speed but I won't be doing that |
I do say "in the snow with NORMAL tyres on your 4x4" |
Custom10 Member Since: 24 Jul 2014 Location: Asker Posts: 12 ![]() ![]() ![]() |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
cruise control in snow....that i dont do
Smart idea, Rambles. I've never had the radar cruise, so I've never thought about it, but that makes sense. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1456 ![]() ![]() |
On the flooded road aspect, as a basic rule of thumb I gauged the rough safe depth as the top of the alloy wheel rim. Not the top of the tyre rubber, but the rim. That way it was simple to stck your head out the window and edge into water watching the water against the wheel.
