Home > Technical (L322) > please help my steering is shot
flow11234
United States 2003 Range Rover Vogue SE 4.4 V8 Giverny Green
I just brought this range rover 2004 with 80k miles. The previous owner Got into an accident . the truck side swipe a couple of cars and then ended up jumping the Sidewalk. The right wheel is pushed into the finder, it drives and it turns but but the wheel rubs.to driver straight I have to turn the steering was as to the logo is vertical. My questions is what need to be Changed to get wheel back in its normal position. Fyi the frame isnt bent.
Post #287043 17th Oct 2014 12:25pm
espaceboy
can you remove the wheels and take some pictures of the suspension components?
Post #287048 17th Oct 2014 12:58pm
flow11234
Ok one second ill do it in a little while
Post #287049 17th Oct 2014 12:59pm
verydisco
Hi Flow
I am afraid that the kind of damage done to the vehicle is much greater than someone asking what is broken online can cope with, really.
However, prepare to replace the suspension wishbone, bolts, and possibly the antiroll bar and its fixing, if you are lucky the steering rack and the strut are ok.
Do not buy the rack from LR or you will... Well you'll need new undertpants.
further pictures will help the diagnosis. Any local mechanic could do such diagnosis though.
Also do no drive the Rangie as it is if you want to save your steering rack and pump.
Keep us posted and do not hesitate to introduce yourself in the dedicated thread. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #287059 17th Oct 2014 2:15pm
Something wrong with my steering also. It's not very responsive when I turn the wheel.
What do you think I should do?
Post #287088 17th Oct 2014 4:22pm
mjdronfield
Laughing
Very good Mr Verbose...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #287096 17th Oct 2014 4:34pm
miggit
Is that what an Air Assisted Steering setup looks like?? Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #287116 17th Oct 2014 5:19pm
flow11234
dam sorry I couldn't rotate the pics
Post #287123 17th Oct 2014 5:37pm
miggit
If the wheel has gone back, you need to get it up in the air to make sure that the front sub-frame is OK and that its just the wishbone thats bent. Your steering is out because the wheel has been pushed closer to the steering rack, which has forced the wheel to point in at the front.
I suspect, from the picture, you'll have to replace the front sub frame. But they are readly available from the breakers (auto salvage) over here, and as such youy should be able to obtain one at a lot less than Land Rover retail!
But I will say that changing this over is a major undertaking, which will requrie the engine being held up on a crane / sling, so that the sub frame can be replaced. A local garage / auto shop should be able todo this. Good luck Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #287125 17th Oct 2014 5:39pm
miggit
I hate to say this but your going to need a steering rack, unless you can find someone to change the track control rod, its well bent! Yesterday I couldn't spell Engineer... Today I are one!
Post #287126 17th Oct 2014 5:43pm
flow11234
This is the other side lol know I clear see the difference to me it look like its the control arms and tie rod end.....what do you guys think
Post #287128 17th Oct 2014 5:48pm
miggit
I'd try a new wish bone and bolts to see how far back in to place (forward) the wheel goes, what ever happens it will have to be replaced. Once it done measure the distance between the centers of the wheels on both sides of the Suv. If your very lucky it will be the same, but if its a fraction out you'll need to look at the sub frame. An Auto Body Shop might be able to pull it back in to place if its a minor difference, oh and dont forget to do the steering rack / track control rod!! Yesterday I couldn't spell Engineer... Today I are one!
Post #287129 17th Oct 2014 5:52pm
You can get a rack end for them....
I hate to say it but if you have to ask on a forum what bits to change then you really shouldn't be attempting this type of repair, there are endless traps you could fall into, you need a proper garage to look it over and change the parts.
As miggit says, it maybe a lot cheaper to get a whole front subframe with all the suspension and swop it over..
Looks like you will have inner wing damage as well and that will require repairing properly before you bolt a wing on.... Pete
Post #287130 17th Oct 2014 5:54pm
Discotigger
Just from the pictures I reckon you need the following:
Replace both steering rack tie ends
Replace both track rod ends
Replace both lower suspension arms
Replace both track control arms and separate ball joints
Check and possibly replace the anti-roll bar and both ARB drop links
Check that the struts have not got damaged or bent.
If the sub frame is not bent, then this should sort the problems, the above parts aren't too expensive, but I'd get the vehicle checked by a garage just to be safe.
Get a copy of Microcat if you can, it'll give you the part nos. for all the above bits.
Post #287132 17th Oct 2014 5:56pm
flow11234
Thanks for all the feeback guys
Post #287157 17th Oct 2014 7:01pm
