Home > Technical (L322) > please help my steering is shot |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
can you remove the wheels and take some pictures of the suspension components? |
17th Oct 2014 11:58am |
flow11234 Member Since: 08 May 2013 Location: pa Posts: 36 |
Ok one second ill do it in a little while |
17th Oct 2014 11:59am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Hi Flow
17th Oct 2014 1:15pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Something wrong with my steering also. It's not very responsive when I turn the wheel.
17th Oct 2014 3:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7798 |
17th Oct 2014 3:34pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Is that what an Air Assisted Steering setup looks like?? Yesterday I couldn't spell Engineer... Today I are one!
17th Oct 2014 4:19pm |
17th Oct 2014 4:37pm |
If the wheel has gone back, you need to get it up in the air to make sure that the front sub-frame is OK and that its just the wishbone thats bent. Your steering is out because the wheel has been pushed closer to the steering rack, which has forced the wheel to point in at the front.
17th Oct 2014 4:39pm |
I hate to say this but your going to need a steering rack, unless you can find someone to change the track control rod, its well bent! Yesterday I couldn't spell Engineer... Today I are one!
17th Oct 2014 4:43pm |
17th Oct 2014 4:48pm |
I'd try a new wish bone and bolts to see how far back in to place (forward) the wheel goes, what ever happens it will have to be replaced. Once it done measure the distance between the centers of the wheels on both sides of the Suv. If your very lucky it will be the same, but if its a fraction out you'll need to look at the sub frame. An Auto Body Shop might be able to pull it back in to place if its a minor difference, oh and dont forget to do the steering rack / track control rod!! Yesterday I couldn't spell Engineer... Today I are one!
17th Oct 2014 4:52pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
You can get a rack end for them....
17th Oct 2014 4:54pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Just from the pictures I reckon you need the following:
17th Oct 2014 4:56pm |
Thanks for all the feeback guys |
17th Oct 2014 6:01pm |
