Home > Maintenance & Mods (L322) > Bosch s5 silver 110ah 020 |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
Thanks Gents - new battery ordered. "On first name terms with my local Dealer......now."
3rd Sep 2013 8:16am |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 |
its the only battery that should really come with a RR |
10th Sep 2013 12:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 |
^ agreed .. ... - .- -.
10th Sep 2013 12:28pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Purchased the Varta .
7th Dec 2013 8:34am |
Apparently had I downloaded their App from the App Store
7th Dec 2013 8:53am |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
fitted a varta 020 a month ago as my 8 year old battery had had it 020 is the one for the td6. |
7th Dec 2013 4:22pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
looks like its a new battery or me as well, can i sqeeze in the 020 in my 4.4 petrol. is bosch and varta made by the same people, i was offered one of those AGM batterys but i fault you have to have a differant alternator to charge them... V8 facelift Range Rover Autobiography 22" wheels.
8th Dec 2013 6:23pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Varta and Bosch batteries are both made in the same American owned Johnson Controls factory in Valencia. Bosch brand owned by Bosch of course, Varta & Optima brand owned by JC Inc. |
8th Dec 2013 7:08pm |
You could use an amg without issues iirc as they normally just upstate the alternator to boost charge them quicker as they are often used in stop start cars due to the amount of quick drains they get from starting the cars up and the need to get he battery charged quickly but in a 4.4 ff you'll be fine. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
8th Dec 2013 9:57pm |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
My new battery made a huge difference. Best £112 spent on the Fatty so far! |
8th Dec 2013 9:59pm |
so what battery did you fit paul. V8 facelift Range Rover Autobiography 22" wheels.
8th Dec 2013 10:05pm |
Daveo i fitted the Bosch S5.
9th Dec 2013 3:27am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i bought the s5 02 bosch, and have the receipt tucked away nicely. when I bought my FF it came with a 1 yr old s5 in it, but it was flat.(car was a non runner you see,) I believe it had been overcharged, or left completely flat.... as it had a very short charge life. it had been bought from Halfords. I took it in for a garuantee check, but they are adamant that it charged and holds charge. I suspected they didn't want to have back on warranty, so I bought same battery from europarts with discount for about £120 I kept their garuantee, and battery has been excellent on the 2002 4.4 I drive. never let me down, no starting issues, no weird electrical issues either. been on for about a year nearly. there is quite a lot of crap on the net about batteries, and there are problems for newer FF owners and programming batteries for these models at dealerships. With a digital multimeter it is possible to determine correct battery charge and normal battery voltage. (Halfords seem to think a little simpler) mine has the blow-off charged connector on the posi. procedure. turn off car and open bonnet, (leave drivers window down incase a central locking problem) open bonnet to service position... allow 20 mins for airbag/nav shutdown, remove neg and then posi, put a rubber glove over each terminal in case they try to flick back to terminals. de-clamp etc. carefully remove black trim poppers and watch them ping out and down drain! prop up plastic with some cardboard, stand on toolbox and lift battery up and onto bulkhead, and reverse procedure. try to get neg terminal onto post quickly, to avoid arc'ing. have key ready incase of alarm. set clock and nav date etc. note...make sure you haven't uncoupled the yellow cable for the terminal blowoff circuit. its thin, and short and gets wrested with pulling the battery cables around. check before you reteminate. then check airbag light etc. |
9th Dec 2013 10:28am |
i will go for the bosch 020 battery, any europarts codes floating around.. V8 facelift Range Rover Autobiography 22" wheels.
9th Dec 2013 8:06pm |
