Home > Technical (L322) > Smokin...? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6703 |
Sounds like you need a bit of a motorway blast to clear out the DPF Got - 2017 SDV8 Autobiography in Loire Blue
10th Aug 2013 12:34pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3720 |
+1 give it the gun !
10th Aug 2013 12:58pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2618 |
Italian tune up requ'd |
10th Aug 2013 1:39pm |
Bigmick Member Since: 22 May 2013 Location: Preston, Lancashire Posts: 10 |
Known problem on some 4.4 tdv8 engines where oil passes from the turbo to the DPF. Get it back to the dealer for repair under warranty Mike
10th Aug 2013 1:50pm |
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 |
Hi,I had the same problem, not often though.
12th Aug 2013 7:05pm |
DanRR Member Since: 17 Aug 2013 Location: London Posts: 2 |
These cars build up oil in the secondary turbo in town driven cars due to sitting idle for most of the time, then when u plant it it spins up and dumps it straight through into the exhaust, its what most of the dpf issues are caused by, filling with oil rather than soot, theres a fix for this involving fitting a more beefy oil drain pipe system which seems to have cured it, take it to a LR dealer its covered under warranty.. |
17th Aug 2013 9:17pm |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 500 |
^+1 DanRR
18th Aug 2013 5:48am |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 |
awesome - same issue, car always used around town; thanks guys!!! |
6th May 2014 8:16am |
all fixed and running perfectly: Thanks to Australs Land Rover Brisbane, 2 x Technical Bulletins - reconfigured power train control module with latest level of software; and carried out modified turbo drain pipe
29th May 2014 7:03am |
