Home > Technical (L322) > Smokin...? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 |
Sounds like you need a bit of a motorway blast to clear out the DPF Got - 2017 SDV8 Autobiography in Loire Blue
10th Aug 2013 11:34am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
+1 give it the gun !
10th Aug 2013 11:58am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2662 |
Italian tune up requ'd |
10th Aug 2013 12:39pm |
Bigmick Member Since: 22 May 2013 Location: Preston, Lancashire Posts: 10 |
Known problem on some 4.4 tdv8 engines where oil passes from the turbo to the DPF. Get it back to the dealer for repair under warranty Mike
10th Aug 2013 12:50pm |
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 |
Hi,I had the same problem, not often though.
12th Aug 2013 6:05pm |
DanRR Member Since: 17 Aug 2013 Location: London Posts: 2 |
These cars build up oil in the secondary turbo in town driven cars due to sitting idle for most of the time, then when u plant it it spins up and dumps it straight through into the exhaust, its what most of the dpf issues are caused by, filling with oil rather than soot, theres a fix for this involving fitting a more beefy oil drain pipe system which seems to have cured it, take it to a LR dealer its covered under warranty.. |
17th Aug 2013 8:17pm |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 506 |
^+1 DanRR
18th Aug 2013 4:48am |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 |
awesome - same issue, car always used around town; thanks guys!!! |
6th May 2014 7:16am |
all fixed and running perfectly: Thanks to Australs Land Rover Brisbane, 2 x Technical Bulletins - reconfigured power train control module with latest level of software; and carried out modified turbo drain pipe
29th May 2014 6:03am |
