Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module
Page 3 of 7 <1234567>
mjdronfield
Excellent. Still very pleased with the ULF system in mine.
I wonder what makes the difference with the 32 / 36 short for pairing then ? There must be a difference somewhere.
Suppose as long as it pairs, it doesn't really matter.
I have Navcoder, and there is a tick box on the Telephone settings to put the ULF in pairing mode, so I don't think it really matters how it gets enabled.
On the Digital TV front, I got a BMW hybrid unit (digital and analogue) from a 2005 X5, and its a straight swap.
Bit pricy on the bay of e, but if you get lucky or can find a BMW breakers.......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #192859 9th Jun 2013 10:31am
kiter
Where did you get the cable for navcoder? I've looked about and getting a bit confused with what I need to buy, other daft question is where do you plug it on the car?
There is a BMW hybrid unit on ebay just but its a wee bit dear - sorely tempted.............
Thanks
Post #193094 10th Jun 2013 3:34pm
put 'navcoder cable' into ebay and load come up, and the OBD is on the right below the light switch.. ... - .- -.
Post #193111 10th Jun 2013 4:06pm
kiter
cheers I did see these but wasnt sure it was the right thing and I stupidly assumed it would be a connection in the boot area - steep learning curve this..........! especially a complete amatuer like me!
Post #193113 10th Jun 2013 4:12pm
mjdronfield
I got one of these ;
http://www.ebay.co.uk/itm/BMW-Programming-...41738a67fd
Works a treat.
Never used all the BMW software that comes on CD=R's with it.
Says you get a trial version of Navcoder, but you can get that off the net.
You've prob done a search on here for Navcoder, so you'll know what you can configure with it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #193120 10th Jun 2013 4:32pm
kiter
Cheers - I'll get one ordered up - really just want to enable the voice recognition for the phone and maybe a few other bits and bobs. Like lights on all the time - everyday car has auto lights and really miss them on the RR. My other half cant believe I've been able to do so much without going near a garage, although I'm probably tempting fate, having said that!
Post #193125 10th Jun 2013 4:46pm
mjdronfield
I enabled my voice recognition with it.
And changed the ID of the ULF so its my chassis number, not one from a BMW.
My mobile now says "L322 xxxxx" connected / disconnected.
Little things............... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #193127 10th Jun 2013 4:51pm
kiter
Hopefully cable be here tomorrow so can play with navcoder tomorrow night when I get home. Bought a hybrid digi TV box as well (got to stop spending money now!) its out of an X5 and coming from Latvia - thought twice but took the risk in the end. It was a bit dearer compared to getting analogue unit upgraded but no faffing with a remote control and at least I will have my old unit to go back in the car if I ever sell it. Did you upgrade the ariel or just stick with the original one?
Post #193479 11th Jun 2013 8:46pm
mjdronfield
I didn't change the aerials, but in saying that, I couldn't find any info as to why I had to. If you find otherwise, let me know.
Seems to work fine, except when I park up at work with the rear up against a wire fence........signal drops in and out and breaks up like crazy. Park the other way, no issues.
The 2 connections for the aerials are not front to back on the hybrid unit, they are side by side, so I'm also not sure as to whether its possible to connect them the wrong way round. Seems to work both ways.
You may also get "Aux In" as on option as a channel, but you'll need the loom to add a dvd player or such like.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #193607 12th Jun 2013 9:42am
mjdronfield
Well, as I'm off work this week, decided to fit a pairing button.
Got one of these from Maplin ;
http://www.maplin.co.uk/locking-push-switch-34857
Thought about mounting it on a plate etc, but decided it would be a bit overkill.
Works a treat ;
Its not seen when the cover is on, and always have the option of remounting later. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #193693 12th Jun 2013 3:44pm
StevePg
Italy
Congratulations to all... this is the best forum on the Range Rover, I've looked everywhere the instructions for re-pinning for BMW ULF L322, here I found what and many other valuable information...
I bought a ULF on the bay in Lettonia (itself seller?), the seller says he upgrade the software to the latest version with SES command
while I wait the ULF I re-pinning with your pattern, thanks again to you, now I finally understood that pin use to make the pairing (32-36)
Sorry for my bad english.
Regards
Post #193973 13th Jun 2013 7:27pm
mjdronfield
You are more than welcome.
If you have any problems, we will do our best to help.
If it makes the rewire clearer, here is the chart I used ;
Your English is much better than my Italian.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #193990 13th Jun 2013 7:45pm
Ash_vogue
Hi guys, I'm abit new to all this, I've got a 2004 full fat and it already has the brick of a phone in the arm rest and I could really do with upgrading it to Bluetooth, could someone please tell me which parts i might need and how to go about this? Also I do I know if I need a wiring loom? And which ulf to buy?
Many thanks
Ashley
Post #196206 25th Jun 2013 11:50pm
StevePg
Italy
The Chart is perfect, thank.
I can use the SES for Tel, Navi and Note, you know if other function are available in SES mode ?
In the navigator I can't set the target in SES mode, I can find distributors or other things in my location but I can't set the destination by voice, it's normal ?
Thank again.
Post #196221 26th Jun 2013 11:14am
Ashley, read this thread ,have a look on our wiki and do a forum search , loads of info on this.. ... - .- -.
Post #196223 26th Jun 2013 12:02pm
