Home > Maintenance & Mods (L322) > flip keys (new order started)
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 3 of 11 <123 4 ... 91011>
magicbob
2003 Range Rover SE Td6 Epsom Green
If yuo can post to Aus, I'll have two, please. Happy to pay postage
Bob
Post #189298 20th May 2013 12:26am
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I'll take one plz Very Happy
see PM
Thx
Post #189366 20th May 2013 11:05am
I will have one too....
Gaz
Post #189367 20th May 2013 11:09am
Ragerover
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Zambezi Silver
ill take one
maybe 2 if my purchase comes off this week
Post #189370 20th May 2013 11:58am
ebajema
Hey Dave, would they work on NAS cars as well ? MY 2010 5.0 SC Galway green and sand interior!!
Post #189371 20th May 2013 12:06pm
I'd be up for the later version if possible please?
Also do they come with a transponder chip in at all as i can reprogram mine and force it to learn new codes Very Happy ?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #189382 20th May 2013 12:54pm
ebajema
The transponder chip is a little loose thingemedo in the old key. They are loose in there so can easily be put in the new key. That part I had working on my two US flip keys. What didn't work was the opening and closing of the doors. The "normal" pairing of key fobs to door lock/unlock won't work on the US flip keys I bought for my US car.
I took the blade of my old crappy key and fitted it to the flip key and together with the transponder I can drive the car fine, just not open and close the doors Sad
Hence my request for Dave's keys Smile
The US and Canada are supposedly on a different frequency with the fobs (for lock/unlock). MY 2010 5.0 SC Galway green and sand interior!!
Post #189383 20th May 2013 12:58pm
Reason i ask EB is that i'd like to not have to butcher the current keys(im lucky and have 2!) but can easily program in another transponder to work with the system thanks to my recent toy purchase... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #189388 20th May 2013 1:18pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
What device is required for chip programming and how easy/difficult is it?
Post #189390 20th May 2013 1:28pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Yes, the new keys come with a blank chip pre-installed.
Post #189395 20th May 2013 1:42pm
Should suit me fine then Smile
Im guessing for programming youd need Testbook(or IDS/SDD)/ Faultmate / Autlogic device that has the ability to really get into the depths of the FF's systems.
I have a Faultmate MSV2 so can play away and recode as much as i need to from the security bits i've looked at so far Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #189397 20th May 2013 1:45pm
ebajema
The Faultmate can sync the keys to the ECU but the transponder code has to be LR generated based on the VIN as far as I know. Now whether you can program the transponder with a different tool, I don't know.
When I received my new dealer purchased key (bought using the VIN) I still had to use the Faultmate, which keys were allowed on the car (up to 6 keys). But that is telling the ECU which pre-programmed transponders are still allowed to work. That way you can un-sync a key that was lost or stolen. MY 2010 5.0 SC Galway green and sand interior!!
Post #189405 20th May 2013 2:15pm
Ahhh, i thought you could force it to learn a new transponder code from a new key? Maybe this means a second hand key could work then but i thought if the transponder was blank it would learn from the car in some way when being programmed? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #189412 20th May 2013 3:12pm
ebajema
Although I am not 100% sure, that is how I think it works. HOWEVER, I also read a recent post on here where someone found a way to program the transponder chips themselves ?? No idea where but search and Stan (preferably in that sequence) should be the solution to that Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #189413 20th May 2013 3:28pm
anything to do with keys then Daveo is the guru, search his posts and all will be revealed.. ... - .- -.
Post #189416 20th May 2013 3:39pm
This topic is locked: you cannot edit posts or make replies.  Back to top
