Home > Maintenance & Mods (L322) > flip keys (new order started)
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 4 of 11 <123 45 ... 91011>
daveo
ok I have done a bit research and found out that the key and circuit board are for up to 05 only, cars like 06/07 that have the same old style key it will not work, they changed the anti-theft system to a tag system as well as most other things after the facelift.
So just to be clear these keys are to replace the old style keys on the 02 to 05 cars.
There are two styles available original and new style; if you’re willing to pay I will post anywhere.
There are two circuit boards frequencies 433 and 315 MHz, we use 433 in the UK so check if you’re outside the UK or have an imported car.
I will give it a few more days and then go through the request to make a list. V8 facelift Range Rover Autobiography 22" wheels.
Post #189483 20th May 2013 7:37pm
ebajema
Hi Dave, mine is a MY2006 but built 05/2005 (North American spec) and it doesn't lock/unlock the doors despite having two flip key 315 MHz fobs. Could that mean that mine is still on the "old" system ?
I tested the batteries (after having them in the ignition for a while) and they seem to have good voltage. MY 2010 5.0 SC Galway green and sand interior!!
Post #189484 20th May 2013 7:42pm
daveo
magicbob wrote:
If yuo can post to Aus, I'll have two, please. Happy to pay postage
Bob
if you pay,they will come Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #189489 20th May 2013 7:52pm
daveo
ok on the 05 they changed with the face lift to the tag system, i dont have the equipment to write transponder for this, but i do for the 05 and younger,
check to see if you have the bmw ews under you centre console,its on the drivers side level with the shifter, if you have that ews then these will work for you... V8 facelift Range Rover Autobiography 22" wheels.
Post #189493 20th May 2013 8:00pm
magicbob
2003 Range Rover SE Td6 Epsom Green
daveo wrote:
Bob
Thanks, Daveo, just let me know how much, how to pay, and it will be done with grateful thanks.
Bob Bow down Bow down
Post #189503 20th May 2013 8:53pm
ebajema
The transponder I have, I took out of my old crappy key. I stuck it in the housing of the flip key I bought from the US. That part works fine and the car starts without issues with the combo (the blade is also taken from the old key). The only thing my flip key fobs won't do, is locking/unlocking the doors. I have gone through the pairing procedure several times and both my old style keys work and the flip keys (both US 315 MHz) won't pair. If I get one of the keys you're talking about, would that then work or is that where the change is done ?
Transferring the blade and transponder is easy Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #189510 20th May 2013 9:20pm
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I have had a similar problem with my flip key, the key wont open,close the doors but will start car Neutral
my original keys still pair fine.
Post #189513 20th May 2013 9:37pm
daveo
if the flip key cam from the usa it will be the wrong frequency.. V8 facelift Range Rover Autobiography 22" wheels.
Post #189904 22nd May 2013 4:11pm
zetjester
My keys came from the far east Laughing I ordered the 433mhz ones, although don't know how you would tell if they had sent 315mhz in error Confused other than why I cant program to lock/open doors Big Cry
Post #190041 23rd May 2013 7:36am
procanon
Can you put me down for 1 please
Post #191315 30th May 2013 1:10pm
ebajema
Dave, does this help you to determine what type mine is ?
Post #191391 30th May 2013 9:29pm
daveo
hi ebajema
its is a ews unit by is not bmw branded, can you take a photo of the board inside,front and back,they are very easy to open and if removed when the ignition is of and key removed you will notve a problem... V8 facelift Range Rover Autobiography 22" wheels.
Post #191394 30th May 2013 9:52pm
ebajema
Hi Dave, you were right, took minutes to extract the PCB. Here are three pics, the front twice and the rear once. Hope this helps in finding out that it is Smile
Post #191444 31st May 2013 10:00am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
That looks suspiciously like a body control module manufactured by a company called Lear. With the EEDS tag I would venture this board was made in Spain? These modules are usually locked and cannot be re programed, although it may be possible to get a reader and program a Transponder chip to one match one of the existing key slots locked into its memory. Occasionally you see a used one of these units being sold on eBay etc, do not buy as they are VIN locked and cannot be programed to a different vehicle. new units are available for around £80 - £100 but must be factory coded to the vehicles VIN by the dealer, or so I'm told.
My Range Rover is also 2006 and likely to have one of these fitted, so hope someone can read these and program an ID44 or ID46 chip match? Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #191458 31st May 2013 12:01pm
Tayas
My key is an old style BMW key but I have an 06 sc. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #191525 1st Jun 2013 8:52am
This topic is locked: you cannot edit posts or make replies.  Back to top
