![]() | Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
Thats interesting. |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
Since my manual is italian, I resorted to the doc you sent me and had 2 questions :
Thanks for the feedback
Fuse 25 is shown in TD6 Vehicle Handbook as immobiliser whereas in the Vehicle wiring diagrams Fuse 25 is not shown in TD6 wiring diagram.
The car does start with 25 removed. I'll also not put back 7 & see. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
Mrmerlin Member Since: 21 Mar 2013 Location: Aurora Colorado USA Posts: 13 ![]() ![]() |
before you do any more testing replace the FSR
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Might also be a good idea to replace the FSR. |
Mr merlin, what a great first post !
Ok thanks.
Ok, I think I'll get one tomorrow or so. Btw, fuses left are 9 11 12 13. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
This might be of interest to you.
Thanks, indeed, will look for corrosion in this area.
Correction, it's the tailgate switch not the tailgate lock.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Instead of messing around with multimeters, just use a clamp meter. 10 times easier.
