Home > In Car Electronics (L322) > Screen goes blank?
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Screen goes blank?
Hi guys
Today on a fair length drive my radio/sat nav screen kept going blank then after a few minutes came back on!
Then off then on etc!
Although it was blank it was still lit up??
Radio worked fine just couldn't see anything
When I got back I had a fiddle with the amp/tuner/dsp wires with no joy?
Any ideas what causes this or is the screen on its way out??
I've bought a water shedder so need to fit that but nothing seems damp? Also it's a brand new mk4 sat unit from Baris only fitted a month or so ago!
Any suggestions appreciated
Thanks
Post #169625 2nd Feb 2013 7:42pm
If you've checked all the connectors, then a battery disconnect/reconnect is worth a go.
Post #169639 2nd Feb 2013 8:40pm
SATVC
It a brand new battery only fitted beginning of December!
Does the disconnect just reset everything??? Ill try that in the morning! Thanks
Post #169640 2nd Feb 2013 8:42pm
Mine does do a "reset" every now and then, but no more than once a week, and only once at a time.
Yours does sound like a cable connection issue ? .
Post #169675 3rd Feb 2013 12:37am
SATVC
It doesn't seem to reset as the radio still works when the screen is blank!
I've got to fit this watershedder at some point so ill take everything out and check every connector!
Would you suggest maybe a little electric grease to keep the moisture out?
I was just hoping its not any of the units failing?
Post #169682 3rd Feb 2013 7:38am
I would try wiggleing (?) each of the various plugs about whilst watching the screen to see if it comes on, including the sat nav connections.
You could paint vaseline in the various pins once you get it working to keep any moisture out.
Post #169692 3rd Feb 2013 9:24am
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
What sat nav do you have RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #169726 3rd Feb 2013 1:28pm
SATVC
I've just fitted a mk4 from Baris a month or so ago!
Post #169729 3rd Feb 2013 1:34pm
Jr-auto-electrics
It's your sat nav that's the problem
I had exactly the same problem.
Is it making a noise when running
Louder than a normal CD player ?? RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #169736 3rd Feb 2013 2:03pm
SATVC
No it sounds like normal??? (As when I first put it in)
It's only been In the car a month or so?
I'll do a reset and remove and refit ect! But atleast I have an area to look at!!
Thankyou!!
Post #169742 3rd Feb 2013 2:47pm
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
Mine does the same with a mk3, my mk4 got water damage so had to drop in the old unit and straight away it started doing the on off routine
Post #169852 3rd Feb 2013 11:30pm
Baris
A few things can cause this.
Speed camera alert firmware - which will cause the nav unit to reset itself, when you go past certain locations. Splash screen will reappear.
TV tuner connections. The actuAl pins on the tuner get rusty, and loosen up. Piug the blue connection from TV tuner into the nav unit. That will eliminate the tv tuner out of the equation.
If its non of the above, send the nav unit back and il test it over here. Do try and get as much info from it as possible, before going that route, as it will help me diagnose quicker.
Post #169880 4th Feb 2013 8:58am
SATVC
Thanks Baris, ill prob send the amp at the same time for upgrade etc!
I can't see it being the sat nav as I've check every day for water etc and had none! Unless like you say firmware prob?
Can the tuner be permanently bypassed if it is a fault with the tuner?? Or would I need a new unit?
Post #169897 4th Feb 2013 9:47am
Baris
Yes, take the blue connection from the tv tuner and plug it into the navigation drive.
I don't use the speed camera alert firmware, so unless you changed it, it shouldn't be that. Does the splash screen pop up, after it goes blank?
Post #169921 4th Feb 2013 10:20am
SATVC
No! The splash used to pop up fine but then one day I opened the door and nothing!! After a few mins the radio screen would pop up then disappear?
And no I haven't changed the firmware etc as I wouldn't have a clue how! Lol
Post #169928 4th Feb 2013 10:32am
