Home > In Car Electronics (L322) > Screen goes blank? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7894 |
If you've checked all the connectors, then a battery disconnect/reconnect is worth a go. |
2nd Feb 2013 9:40pm |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 |
It a brand new battery only fitted beginning of December!
2nd Feb 2013 9:42pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Mine does do a "reset" every now and then, but no more than once a week, and only once at a time.
3rd Feb 2013 1:37am |
It doesn't seem to reset as the radio still works when the screen is blank!
3rd Feb 2013 8:38am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
I would try wiggleing (?) each of the various plugs about whilst watching the screen to see if it comes on, including the sat nav connections.
3rd Feb 2013 10:24am |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
What sat nav do you have RANGE ROVER 04 TD6
3rd Feb 2013 2:28pm |
I've just fitted a mk4 from Baris a month or so ago! |
3rd Feb 2013 2:34pm |
It's your sat nav that's the problem
3rd Feb 2013 3:03pm |
No it sounds like normal??? (As when I first put it in)
3rd Feb 2013 3:47pm |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 |
Mine does the same with a mk3, my mk4 got water damage so had to drop in the old unit and straight away it started doing the on off routine |
4th Feb 2013 12:30am |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 |
A few things can cause this.
4th Feb 2013 9:58am |
Thanks Baris, ill prob send the amp at the same time for upgrade etc!
4th Feb 2013 10:47am |
Yes, take the blue connection from the tv tuner and plug it into the navigation drive.
4th Feb 2013 11:20am |
No! The splash used to pop up fine but then one day I opened the door and nothing!! After a few mins the radio screen would pop up then disappear?
4th Feb 2013 11:32am |
