Home > Technical (L322) > ZF 6HP26 teardown |
Phil, I've sent you a PM
20th Nov 2012 11:19pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Excellent thread, chaps!!
21st Nov 2012 7:24am |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Great post Phil. You really are an asset to this forum. MY2010 TDV8 Vogue Ipanema Sand
24th Nov 2012 9:58am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 955 |
Okay, so making a start with pulling apart the first of the various sub-assemblies.....
25th Nov 2012 1:45am |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
fascinating stuff Phil, a true asset to the forum. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
25th Nov 2012 2:09pm |
Top reading material indeed. |
25th Nov 2012 2:11pm |
g4mudman Member Since: 07 Oct 2012 Location: Bedford Posts: 12 |
Great work RRPhil.........would be good to know if it would be possible to fit a ZF6 speed in too a TD6 Range Rover, a little electronic trickery would be needed but the fitting should be fairly straight forward......bellhousing, mountings and props...simples |
27th Nov 2012 2:15pm |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
Like a good few people on here, I also do not have a clue what is going on & am staggered by the number of gears, rings etc & am clueless how it would all go back together!
27th Nov 2012 3:37pm |
Nice idea. I would imagine that the first person that successfully transplants the 6HP26 into a TD6, and gets it running properly, will clean up - what a popular conversion that would be! The 6HP26 is around 30mm shorter than the 5L40-E in the L322 installation :
so potentially there’s enough space for an adaptor plate between the bellhousing and the RFOB. The 5L40-E bellhousing (shown at the top in the photo below) is quite a bit smaller than the 6HP26 :
Obviously there would be starter motor, TC nose support and flex-plate issues that would have to be dealt with. As the interface for the transfer box would be different at the back :
it would make sense to carry over the DD295 transfer case provided that the propshafts could be made to fit and the positioning of the front joint isn’t too dissimilar. With the 4.10 final drive in the TD6, maximum overdrive ratio would be around 31mph/1000rpm in 6th gear. Because 1st gear ratio in the 6HP26 is 4.17 compared with 3.42 in the 5L40-E, and because the torque converter K-factor and stall torque ratio will have been matched against the 640Nm TDV8 engine output (compared with only 390Nm for the BMW TD6) there would be some work to do matching the torque converter I think. Anyway, the mechanical issues would pale into insignificance compared with the electronic/control ones – over to you Steve! Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
27th Nov 2012 11:06pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
28th Nov 2012 12:11am |
Hi Phil thanks for the detailed reply, how about using the auto box and torque converter from a D3 disco? not as powerful as the TDV8 but still a few little issues to overcome
28th Nov 2012 1:00am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1322 |
Very interesting breakdown of the box. You can see how it is a bit simpler than what went before.
28th Nov 2012 11:05am |
I think you'd need the Gbox, Transfer box, Front Diff, Rear Diff, and all the shafts unless the splines are the same. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Nov 2012 1:17pm |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 |
Phil
6th Dec 2012 11:59am |
