Home > Technical (L322) > ZF 6HP26 teardown
Page 2 of 3 <123>
SteveMFr
Site Sponsor
Phil, I've sent you a PM
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #152421 20th Nov 2012 10:19pm
Excellent thread, chaps!! Bow down
ZF 6-speed retrofitted into an '02, eh? I imagine if the units are the same size, then surely it's just a matter of reprogramming to get it working?
Please keep us updated. Si. <This is my name.
Post #152456 21st Nov 2012 6:24am
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Great post Phil. You really are an asset to this forum. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153081 24th Nov 2012 8:58am
RRPhil
Okay, so making a start with pulling apart the first of the various sub-assemblies.....
First the A & E clutch assembly, which includes the front simple epicyclic
This assembly comes apart by simply releasing the snap ring which holds the B-clutch hub to the A-clutch drum
The various components which make up the assembly can be seen below. On the right is the E-clutch hub which drives the carrier of the rear Ravigneaux epicyclic – ZF call this the intermediate shaft. The drum with the holes in it is the A-clutch hub which, through the hollow shaft, drives the rear sun gear of the Ravigneaux unit.
So here is the A-clutch assembly with the front simple epicyclic attached
The clutch pack slides out after removing the snap ring and this plastic component is an oil catcher that channels fluid down the centre of the planet pins to lubricate the planet gear bearings
It took me a little while to fathom out how to detach the epicyclic carrier and sun gear from the A-clutch. Although you probably can’t make it out in the photo there’s a clip which holds the carrier in place and it is removed by levering it out of its groove using a small screwdriver through the gaps down the side of two of the planet gears
The clip can be seen more clearly below which shows the epicyclic once removed
and this is how the A-clutch assembly now looks
The clutch piston return spring then has to be compressed in order to remove the retaining circlip and I was pleasantly surprised to find that one of the tools I’d had made up for stripping down the 5HP24 clutches fitted this one fine
So the oil dam plate can be removed together with the circlip
revealing the clutch piston return spring
To remove the piston it’s easiest to place the A-clutch drum back on to the oil pump assembly and then apply air pressure into the feed hole
The piston then pops out and these are all the components that make up the A-clutch and front epicyclic assembly
Moving now onto the E-clutch assembly. The E-clutch assembly is part of the ‘input shaft’ of the transmission which is driven directly by the torque converter turbine
The photo shows that the annulus gear of the front simple epicyclic is EB welded to the E-clutch drum and so is permanently driven by the transmission input shaft
Once the clutch pack had been lifted out of the drum, I was again pleasantly surprised to find that one of my 5HP24 clutch spring compression tools fitted the E-clutch spring retainer perfectly, allowing me to remove the circlip without difficulty
and then the spring and piston could be removed
Phil
Post #153293 25th Nov 2012 12:45am
TugRR
. . . . Well, Phil, I have little idea of what you are doing in all of this, but I'm thoroughly enjoying reading it !
Keep up the good work -
Thumbs Up Where do you go after one of these . . . ?
Post #153350 25th Nov 2012 10:54am
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
fascinating stuff Phil, a true asset to the forum. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #153361 25th Nov 2012 1:09pm
mzplcg
Top reading material indeed. Thumbs Up
Post #153362 25th Nov 2012 1:11pm
g4mudman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Great work RRPhil.........would be good to know if it would be possible to fit a ZF6 speed in too a TD6 Range Rover, a little electronic trickery would be needed but the fitting should be fairly straight forward......bellhousing, mountings and props...simples Thumbs Up
Post #153835 27th Nov 2012 1:15pm
piecost76
Like a good few people on here, I also do not have a clue what is going on & am staggered by the number of gears, rings etc & am clueless how it would all go back together!
Well done Phil & please keep up the excellent work, I think everyone would want to buy a rebuilt gearbox from you Thumbs Up Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #153849 27th Nov 2012 2:37pm
RRPhil
g4mudman wrote:
...would be good to know if it would be possible to fit a ZF6 speed in too a TD6 Range Rover....
Nice idea. I would imagine that the first person that successfully transplants the 6HP26 into a TD6, and gets it running properly, will clean up - what a popular conversion that would be!
The 6HP26 is around 30mm shorter than the 5L40-E in the L322 installation :
so potentially there’s enough space for an adaptor plate between the bellhousing and the RFOB. The 5L40-E bellhousing (shown at the top in the photo below) is quite a bit smaller than the 6HP26 :
Obviously there would be starter motor, TC nose support and flex-plate issues that would have to be dealt with.
As the interface for the transfer box would be different at the back :
it would make sense to carry over the DD295 transfer case provided that the propshafts could be made to fit and the positioning of the front joint isn’t too dissimilar.
With the 4.10 final drive in the TD6, maximum overdrive ratio would be around 31mph/1000rpm in 6th gear. Because 1st gear ratio in the 6HP26 is 4.17 compared with 3.42 in the 5L40-E, and because the torque converter K-factor and stall torque ratio will have been matched against the 640Nm TDV8 engine output (compared with only 390Nm for the BMW TD6) there would be some work to do matching the torque converter I think.
Anyway, the mechanical issues would pale into insignificance compared with the electronic/control ones – over to you Steve!
Phil
Post #153971 27th Nov 2012 10:06pm
Don't know what all the fuss is about! Whistle [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #154001 27th Nov 2012 11:11pm
g4mudman
Hi Phil thanks for the detailed reply, how about using the auto box and torque converter from a D3 disco? not as powerful as the TDV8 but still a few little issues to overcome Bow down
Alan
Post #154005 28th Nov 2012 12:00am
fisha
Very interesting breakdown of the box. You can see how it is a bit simpler than what went before.
Regarding the electrical issues, doesn't the box simply need told the correct values over a can-bus connection and could that not be done by a custom interface device ? 3 V8 or else ...
Post #154052 28th Nov 2012 10:05am
I think you'd need the Gbox, Transfer box, Front Diff, Rear Diff, and all the shafts unless the splines are the same. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #154068 28th Nov 2012 12:17pm
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Phil
From what I have read looking at the ZF 6HP24 variants. I found that BMW fitted this gearbox to the TD6 (M57) in the 730d sold in Europe between 2002-2005. Also it was used again behind the M57 in the E63/64 6 series coupes from 2003-2007
It was not made available to other BMW vehicles because they were marketed as the prestige vehicles in the BMW lineup.
Surely these boxes were communicating on the old canbus system ? as BMW had big electronic issues in this period with it's IDrive system !
Is it worth more investigation ?
Laurie
Post #155715 6th Dec 2012 10:59am
Page 2 of 3 <123>
