![]() | Home > In Car Electronics (L322) > lost cd, radio, gps screen, voice control etc |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi again wiggs, just realised that you dont accept units that are not working |
http://www.kufatec.de/shop/en/Accessories/...r-Transfer Bluetooth Exchange www.bluetoothexchange.co.uk |
Just unplug the most connector from each unit ( one at a time ) and plug it in the most loop . If the system comes back to life you have found the faulty module |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Do you know anyone else that has a RR?
hi paul, no i dont im afriad. i dont know if this is causing the problem as i lost the phone first but still had everything else running for around 4 months before it all stopped when i jumped the car? i do have it booked into a RR specialist to do a diagnostic but i wonder if there computer would find this problem.? i dont want a big labour bill for them to end up telling me they dont know what the problem is so i might just cancel the appointment and try sort it myself.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Read this... Cheap way of proving phone module is inop.
HI GUYS? thanks for all your replies regarding this issue. i will give you my findings when i get on and check connections , test the nokia optic, disconnect the new battery etc, but i am unable to do this before the coming weekend so you can all take a breather with your replies |
hi folks, ok i have started my investigations into the audio/nav screen problems and today i have had the battery disconnected for the last 7 hours. i removed both leads. i reconnected and start up, but alas, the fauls are still as they were. so that confirms it not the battery that caused the problem. next on the list will be checking all the connections and then start by checking the nokia module. i should have my MOST LOOP by then so will let you all know. i was going to take the optic plug out of the nokie and put them in the straw as suggested as a quick test, but knowing my luck i might damage something? so would rather wait for the loop.
HI FOLKS. whilst i am trying to get to grips with the problem i have re the loss of the audio/navigation screen etc, i have the RR booked into the garage for a service on tuesday. i had mentioned to them the problems i have regarding the gps etc and they said they would do a diagnostic to see if they could find the problem. i dont know if they meant putting it on the computer or just trying to find the fault by playing around with the plugs, etc etc.? if it is the former, do you think the dealer computer is capable of finding a fault like this? if so how long do you think it would take to go through the system check? so i have an idea of the cost BEFORE i give them the go ahead !!!
Why not wait till you get your Most loop?? You have to rule out the easy stuff first. You have got to do this methodically.. Or just put it into a garage and be done with it!! Previously..
I presume you have checked Fuse 49, as this is one thing that would give your problems. Before going to a french garage I would be checking to see if you you have 12V and earth to your satnav unit with the ignition on.
HI again, yes i guess that would make sense. i will just get the service done i think and if the worst comes to the worst, i will plan a short trip to the uk and book it into a dealer there.
