![]() | Home > In Car Electronics (L322) > lost cd, radio, gps screen, voice control etc |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi folks, i have been advised to join this site with the hope that i can get my range rover back to all systems go. so i will first try to explain the events that led to the systems in question going down. this might take a little time so bare with me.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35540 ![]() ![]() |
back to basics first Bob, disconnect the battery and wait 20 minutes , reconnect and turn the steering wheel fully left and then full right...this procedure is in our wiki ... ... - .- -.
Get the alternator checked. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
Not specific help, but you say "( touch screen version but not mk 4 )", For future ref, the Mk3 and Mk4 sat nav units are BMW units and are only applicable to the non-touchscreen early L322's.
hi guy's
Hi mate.
hi mjdronfield
Hi Bob,
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
If you have Bluetooth ... Then remove the 54 pin plug and check for water ingress on the connector and module ( blue looking paste on terminals ) Bluetooth Exchange www.bluetoothexchange.co.uk |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I agree with Wiggs.
hi, well i did have blue tooth several months ago and all was working fine . mobile used to link to the bluetooth even before i go into the seat, then one day i got in, noticed phone had not connected to bluetooth, so tried to do it manually and just got a no phone connected message. even trying to pair it just said system no available,?
hi paul just seen your reply. yes i do have the nokia module but lost the use of the bluetooth connection months ago. the loss of everything else is recent but do you think it is all connected and if so what should i look to be doing next,
Have a look here
hi wiggs thanks for that, i will check the plugs and if it still doesent work if and after i get the screen back up, i will check the number and send it off to you
