Home > In Car Electronics (L322) > lost cd, radio, gps screen, voice control etc
Page 2 of 5 <12345>
wiggs
Laughing
I don't want your waterlogged module .. It's no good to me . Shocked Laughing
What you really need is most loop ... This will allow you to unplug each module and test which one is at fault .
Water in the Bluetooth module is quite common ... I removed one the other week ... And tipped it upside down ... It was like a river flowing out Shocked Bluetooth Exchange www.bluetoothexchange.co.uk
Post #153717 26th Nov 2012 10:02pm
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
hi again wiggs, just realised that you dont accept units that are not working Embarassed , so forget the last reply. hopefully it will start working again and is just due to dirty connections etc? Whistle Whistle Exclamation
bob
Post #153721 26th Nov 2012 10:08pm
BOBCUSSEN
Confused what is most loop Confused and where can i get that from? it sounds like the way to find my problem Rolling Eyes Rolling Eyes Exclamation Exclamation
Post #153726 26th Nov 2012 10:13pm
wiggs
http://www.kufatec.de/shop/en/Accessories/...r-Transfer Bluetooth Exchange www.bluetoothexchange.co.uk
Post #153736 26th Nov 2012 10:31pm
wiggs
Just unplug the most connector from each unit ( one at a time ) and plug it in the most loop . If the system comes back to life you have found the faulty module Thumbs Up Bluetooth Exchange www.bluetoothexchange.co.uk
Post #153743 26th Nov 2012 10:43pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Do you know anyone else that has a RR?
You could swap the phone module over to check yours.
Post #153750 26th Nov 2012 11:18pm
BOBCUSSEN
hi paul, no i dont im afriad. i dont know if this is causing the problem as i lost the phone first but still had everything else running for around 4 months before it all stopped when i jumped the car? i do have it booked into a RR specialist to do a diagnostic but i wonder if there computer would find this problem.? i dont want a big labour bill for them to end up telling me they dont know what the problem is so i might just cancel the appointment and try sort it myself.
i will send off for this most loop though as it sounds a handy thing to have around.
bob
Post #153889 27th Nov 2012 6:10pm
Read this... Cheap way of proving phone module is inop.
http://www.fullfatrr.com/forum/post99656.html#99656 Previously..
Post #153891 27th Nov 2012 6:23pm
I posted this on your other post.. It should be here.
Nokia is the Bluetooth module. There are 2 fibre optic cables go into each unit, an input and an output. If you take the connector out of the Nokia, then take both cables out of the connector (they are held in with a little clip). If you line up the ends perfectly the signal goes out of one cable and into the next, simulating passing through the Nokia. This bypasses the Nokia and if that was the only fault, the system will come back to life!
I put the fibre cable ends in a straw and taped a piece of metal to it to keep it straight.
Good luck Thumbs Up Previously..
Post #153924 27th Nov 2012 8:15pm
BOBCUSSEN
HI GUYS? thanks for all your replies regarding this issue. i will give you my findings when i get on and check connections , test the nokia optic, disconnect the new battery etc, but i am unable to do this before the coming weekend so you can all take a breather with your replies Exclamation Exclamation Rolling Eyes Rolling Eyes
i have also ordered the most optic loop which i think will come in handy in future trouble shooting i think.
however, as it has been suggested that my first port of call is re disconnecting the battery now that the new one has been fitted --- would it make sense to do this AFTER the units and connections have been checked, Question thentry the disconnect proceedure after that if still not working Confused Confused , or would you suggest to go ahead with the disconnect in the first instance Question Question Question
bob
Post #154150 28th Nov 2012 5:50pm
BOBCUSSEN
hi folks, ok i have started my investigations into the audio/nav screen problems and today i have had the battery disconnected for the last 7 hours. i removed both leads. i reconnected and start up, but alas, the fauls are still as they were. so that confirms it not the battery that caused the problem. next on the list will be checking all the connections and then start by checking the nokia module. i should have my MOST LOOP by then so will let you all know. i was going to take the optic plug out of the nokie and put them in the straw as suggested as a quick test, but knowing my luck i might damage something? so would rather wait for the loop.
bob
Post #154434 29th Nov 2012 8:12pm
BOBCUSSEN
HI FOLKS. whilst i am trying to get to grips with the problem i have re the loss of the audio/navigation screen etc, i have the RR booked into the garage for a service on tuesday. i had mentioned to them the problems i have regarding the gps etc and they said they would do a diagnostic to see if they could find the problem. i dont know if they meant putting it on the computer or just trying to find the fault by playing around with the plugs, etc etc.? if it is the former, do you think the dealer computer is capable of finding a fault like this? if so how long do you think it would take to go through the system check? so i have an idea of the cost BEFORE i give them the go ahead !!!
the reason i ask is because the garage suggested that they would need the vehicle for at least a full day???!!!, which would be around 700euro labour charges. the problem with these french garages is that they will try it on simply because you are english,
bob
Post #154928 2nd Dec 2012 7:37pm
Why not wait till you get your Most loop?? You have to rule out the easy stuff first. You have got to do this methodically.. Or just put it into a garage and be done with it!! Previously..
Post #154931 2nd Dec 2012 7:41pm
I presume you have checked Fuse 49, as this is one thing that would give your problems. Before going to a french garage I would be checking to see if you you have 12V and earth to your satnav unit with the ignition on.
Sorry, can't help with french garages, don't use them. Smile
Post #154932 2nd Dec 2012 7:43pm
BOBCUSSEN
HI again, yes i guess that would make sense. i will just get the service done i think and if the worst comes to the worst, i will plan a short trip to the uk and book it into a dealer there.
with regards to fuse 49, i have checked the fuse and it seems ok, also i assume the satnav is the dvd rom in the boot? Embarassed , well it is working in as much that i can remove and insert the disc, so i guess that means it is working Question Question Question Question .
of coarse please correct me if im wrong
regards
bob
Post #154936 2nd Dec 2012 8:03pm
Page 2 of 5 <12345>
