![]() | Home > In Car Electronics (L322) > lost cd, radio, gps screen, voice control etc |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
me again, jus to add to my last reply, with regard to fuse 49; the book shows it is a 30amp fuse but the one i have in place is 10amp ???? it has been there since i have owned the car so i assume this is not a problem |
I would check in the handbook to make sure this is the correct fuse and it's rating. |
well i have looked in the handbook and it shows that it shouls be 30 amp for no 49? |
yes the book states the fuse if for 'quote' navigation system, on board computer, on board monitor and audio system ?? |
Don't know what to suggest re fuse 49, if it was my car I would change it to 30A.
hi nicedayforit, im a little confused now, i have just gone out to the motor and checked the fuse panel again. the fuse in place 49 is actually 15amp not 10 as i first said, the fuse cover also shows it should be 15amp in this position ? but the handbook defo states it should be a 30amp fuse?
Can't help you with Fuse 49, mines definitely 30A. Could be different for your touchscreen but the handbook hasn't caught up.
is that the plastic floor flap sitting just in front of the rear left access door where the satnav/ lear amp etc is located. |
No, it's the black panel below that, looks like a tray. |
ok i think i know where your talking about. sorry for the dumb questions but if i dont know, i need to ask |
HI GUYS just a quick one !! i have just returned from the range rover garage as just had a oil change. ( 198euro) JUST for 8 litres of oil . ( think i will arrange servicing/weekend break in uk next time )
bizzybus Member Since: 19 Aug 2012 Location: merseyside Posts: 53 ![]() ![]() ![]() |
Hi sorry to butt in but i am watching this as i am having same radio/cd/sat problem but noted your comment re oil change. National tyres are doing oil changes at the minute for £85.00 Castrol Edge 5W40 Fully Synthetic (includes oil filter) i have used them a few times now without probs. Worth considering on your next uk visit.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Bob, you just need to hold the 2 ends of the optics together when you unclip them from the Nokia connector. It only takes a minute and is very easy to do. From reading the posts, you are going round in circles mate. If your fuses were blown you would have no power, but you say there is power to everything?! If you want to rule out the Nokia go and take both optic cables out of the holder, touch them tightly together and if the nokia was at fault, the system will burst into life. Previously..
hi guys, thanks for the replies, firstly regarding the oil change, yes i am now going to tie a yearly visit in with a service etc in the uk. i have just been charged 370euo for an oil change and a 35 minute dianostic on the computer. so lesson finely learnt.
