Home > Technical (L322) > Time for FBH- what do I need to buy then? |
Found the answer to everyones FBH problems
24th Nov 2012 8:44am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
do they do a remote for that... ... - .- -.
24th Nov 2012 8:47am |
This is about as remote as you can get
24th Nov 2012 8:54am |
24th Nov 2012 8:56am |
24th Nov 2012 11:21am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Would anyone be so kind as to post a photo of the unit in situ? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
25th Nov 2012 12:59pm |
I put a bid of £30 on this and ended up winning it.
28th Nov 2012 9:55am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Hi noddy,
28th Nov 2012 10:04am |
This is the rear of my vehicle- cant see any Telestart unit. Where does it normally live?
28th Nov 2012 2:39pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
It should be mounted behind that siemens whits box thingy but from here I can't see yours , if you see what I mean . 2008 MY Supercharged
28th Nov 2012 5:37pm |
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 |
Hi it should be behind the parking sensor module but your white plug is visible in the picture so good chance you dont have a reciever fitted |
28th Nov 2012 7:05pm |
Hi Noddy,
28th Nov 2012 8:31pm |
Thanks Steve for the info
29th Nov 2012 12:22am |
I am by no means a Webssto product expert, but AFAIK you need a sender and receiver from the same series. This is why I posted 'just buy a T60 set and be done with it' earlier. Sure the newer units are better - but at some point the addtl return is very marginal.
29th Nov 2012 6:42am |
Patricktet Member Since: 04 Aug 2013 Location: Norway Posts: 7 |
Has anyone tried to upgrade from T90/91 to T100 HTM? Any recommendations for a GSM solution? The Webasto TC3 iphone interface is not very refined as it just composes an sms that you have to send. I found a finnish product that looks good, anyone tried it? http://www.embelin.fi/index.php?page=remuc_eng MY 06 Vogue TD6 Buckingham Blue |
13th Sep 2013 11:56am |
