![]() | Home > Technical (L322) > Time for FBH- what do I need to buy then? |
Found the answer to everyones FBH problems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
do they do a remote for that... |
This is about as remote as you can get |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Would anyone be so kind as to post a photo of the unit in situ? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I put a bid of £30 on this and ended up winning it.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Hi noddy,
This is the rear of my vehicle- cant see any Telestart unit. Where does it normally live?
It should be mounted behind that siemens whits box thingy but from here I can't see yours , if you see what I mean . 2008 MY Supercharged
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
Hi it should be behind the parking sensor module but your white plug is visible in the picture so good chance you dont have a reciever fitted |
Hi Noddy,
Thanks Steve for the info
I am by no means a Webssto product expert, but AFAIK you need a sender and receiver from the same series. This is why I posted 'just buy a T60 set and be done with it' earlier. Sure the newer units are better - but at some point the addtl return is very marginal. |
Patricktet Member Since: 04 Aug 2013 Location: Norway Posts: 7 ![]() ![]() |
Has anyone tried to upgrade from T90/91 to T100 HTM? Any recommendations for a GSM solution? The Webasto TC3 iphone interface is not very refined as it just composes an sms that you have to send. I found a finnish product that looks good, anyone tried it? http://www.embelin.fi/index.php?page=remuc_eng MY 06 Vogue TD6 Buckingham Blue |
