Home > Technical (L322) > Won't start - Immobiliser problems ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 |
there are used ones on ebay starting around £45'ish but not sure if it has to be coded by the dealer..
1st Nov 2012 11:24am |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 739 |
If it was a wiring problem, would it still show 'immobiliser(ews)' fault code ? |
1st Nov 2012 12:01pm |
the ews immobiliser error refers to the immobiliser itself , ews stands for Elektronische WegfahrSperre which means 'electronic immobiliser' in german....
1st Nov 2012 12:13pm |
I'll get a new battery for the remote tomorrow and try it ... got to be worth going for the cheapest option first. |
1st Nov 2012 4:31pm |
1st Nov 2012 4:48pm |
Will the Bosch S5 fit the key? |
1st Nov 2012 4:58pm |
Couldn't wait - been out and got new battery ..... No different |
1st Nov 2012 5:15pm |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
Use this link to program the spare key and try starting with that one then at least that eliminates key failure and you will have two keys
1st Nov 2012 5:31pm |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Just a thought in line fuel pump ????? Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
1st Nov 2012 6:44pm |
Would that stop it cranking ? |
1st Nov 2012 6:51pm |
No |
1st Nov 2012 6:54pm |
Can you have someone turn the key while you tap the starter motor/relay with a heavy piece of wood or rubber/wooden hammer ?? Just to make sure the relay or starter motor are not at fault. MY 2010 5.0 SC Galway green and sand interior!!
1st Nov 2012 7:00pm |
There's no power going to the starter solenoid cable when cranking.. |
1st Nov 2012 7:13pm |
Looking at the Workshop manual for the 2005 TD6, you may be right that the problem is in the immobilizer module
1st Nov 2012 7:29pm |
