Home > Technical (L322) > Won't start - Immobiliser problems ?
Page 2 of 4 <1234>
there are used ones on ebay starting around £45'ish but not sure if it has to be coded by the dealer..
http://www.ebay.co.uk/itm/Range-Rover-L322...23235ce630 ... - .- -.
Post #149304 1st Nov 2012 11:24am
ebajema
The transponder that activates the immobilizer on the pre-flip style keys are not powered, so your spare key should still disengage the steering lock.
For the spare key, with a new battery you probably have to do the re-pairing trick (BOTH keys to be done) that is described on the forum as well.
Back to the problem at hand then. It can be that your immobilizer module is not doing all it needs to do. It unlocks the steering but does not activate the starting circuit. However considering that it does work sometimes makes me think it is a relay or still a wiring/contact problem. If the immo module fails completely then it won't work at all (usually).
Check if there are any relays involved in the starting process and check them/replace them (relays are usually quite cheap).
Good luck. MY 2010 5.0 SC Galway green and sand interior!!
Post #149306 1st Nov 2012 11:32am
Johnte
If it was a wiring problem, would it still show 'immobiliser(ews)' fault code ?
Post #149313 1st Nov 2012 12:01pm
the ews immobiliser error refers to the immobiliser itself , ews stands for Elektronische WegfahrSperre which means 'electronic immobiliser' in german....
i think it could be your key with a low battery cos consensus on the web is that immobilisers rarely go wrong... ... - .- -.
Post #149314 1st Nov 2012 12:13pm
Johnte
I'll get a new battery for the remote tomorrow and try it ... got to be worth going for the cheapest option first.
Post #149352 1st Nov 2012 4:31pm
Thumbs Up ... - .- -.
Post #149358 1st Nov 2012 4:48pm
Will the Bosch S5 fit the key?
Post #149361 1st Nov 2012 4:58pm
Johnte
Couldn't wait - been out and got new battery ..... No different Big Cry
Post #149366 1st Nov 2012 5:15pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Use this link to program the spare key and try starting with that one then at least that eliminates key failure and you will have two keys
http://www.roverupgrades.com/Range_Rover_Hidden_menus.html
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #149370 1st Nov 2012 5:31pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Just a thought in line fuel pump ????? Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #149381 1st Nov 2012 6:44pm
Johnte
Would that stop it cranking ? Confused
Post #149384 1st Nov 2012 6:51pm
No
Post #149386 1st Nov 2012 6:54pm
ebajema
Can you have someone turn the key while you tap the starter motor/relay with a heavy piece of wood or rubber/wooden hammer ?? Just to make sure the relay or starter motor are not at fault. MY 2010 5.0 SC Galway green and sand interior!!
Post #149388 1st Nov 2012 7:00pm
Johnte
There's no power going to the starter solenoid cable when cranking..
Post #149391 1st Nov 2012 7:13pm
ebajema
Looking at the Workshop manual for the 2005 TD6, you may be right that the problem is in the immobilizer module Sad
The immobilizer "allows" the starter relay to engage so I am assuming there is a switch of some sorts in the module that activates the starter relay.
When the immobilizer module is changed, you need to "tell" the electronics that it has happened, either using a Faultmate or T4 etc. Not sure what the "other" units can do (Hawkeye, IID etc.) in this respect. MY 2010 5.0 SC Galway green and sand interior!!
Post #149392 1st Nov 2012 7:29pm
Page 2 of 4 <1234>
