Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
From Patrick at GAP Diagnostic some time ago
10th Oct 2012 2:17pm |
Yes, the message wording can be misleading. Will work on changing it in one of the coming updates.
11th Oct 2012 11:58am |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
Sorry if this has been posted before - I have read most of this thread, but didn't see what I was looking for.
14th Oct 2012 6:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
peeps leave sat navs in cars so i should think it would be ok ..i'd maybe put it in a small coolbox of some kind.. ... - .- -.
14th Oct 2012 10:43am |
Thanks, but that worries me a bit as my cheapy sat nav died last year while in the centre console of my work car on a 42 degree day... Mind you, I would like to think that the IID tool is a bit better built than an Aldi sat nav...
14th Oct 2012 11:29am |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 |
Hi SteveMFr, I've just spent a good few hours trawling through the various IID Tool threads and what a fantastic product you guys have created.
14th Oct 2012 12:36pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
HI, On the LCM it has cold and hot bulb monitoring,this is what makes your led lights go made on start up, can this be swithced off with the tool for the hot monitoring, i do think i have seen it for the cold monitoring but not the hot.
29th Oct 2012 8:12am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3788 |
Guys,
29th Oct 2012 1:01pm |
getting to grips with IIDtool, looking for the LCM programing section. is there a more detailed schematic map to guide you through its option's, also looking for the rain sensor programing. V8 facelift Range Rover Autobiography 22" wheels.
4th Nov 2012 8:02pm |
first post or the gap site Dave.. ... - .- -.
4th Nov 2012 8:52pm |
hi stan, looked at the site and the schimatic in the manual i downloaded but after entering calibration it seems to be all EAS settings, V8 facelift Range Rover Autobiography 22" wheels.
4th Nov 2012 10:14pm |
Steve ? ... - .- -.
5th Nov 2012 8:08am |
Hi Dave,
Yes, the cold monitoring is what makes LEDs flash on start (cold bulbs). The LCM runs short pulses of power through the bulbs to check continuity. On incandescent bulbs you don't see this, but LEDs light immediately. Hot monitoring checks that the bulbs have continuity while they are turned on (hot bulbs). Both hot and cold monitoring can be switched on and off in Car Config>LCM.
We will make a complete tree of CCF-Editing options (Car Config) available when the FW development has been completed (hopefully w/in the next 8 weeks). At the moment you simply scroll through the options... If you have any questions about the availability of an option, please post. IIDTool menu->Car Config-> BPM-Body Processor->Rain Sensor
These options are not under Calibration but rather under Car Config (see tree below). You will not have the 'Car Config' menu item if you are still on FW 2.14. Also, please note the restore Car Config and CCF in Save/Restore. Just in case you get into trouble you can always go back to the original settings. HTH (click for full sized image)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
6th Nov 2012 8:49am |
Hi SAppie. Missed this completely - sorry! Yes, you will need 2 IIDTools as the FW is different. And yes, within the IIDTool types, you can add more VINs (e.g. 2 D3's, 2 06-09 L322's, etc). RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
6th Nov 2012 9:34am |
