Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 15 of 49 <123 ... 141516 ... 474849>
mzplcg
OK, I have a technical question again then please. It's not immediately apparent to me yet but can this tool reset the gearbox ECU adaptives section at all?
Thanks. Dom.
Post #143937 1st Oct 2012 11:36am
its doesn't dom, be nice to do that though.. ... - .- -.
Post #143973 1st Oct 2012 1:21pm
daveo
well after all the probs i had with britparts i am happy to say my IIDTool ison its way, Very Happy ..no help from britparts, they my be a good supplier but first impressions were very bad,
thanks steve for your help V8 facelift Range Rover Autobiography 22" wheels.
Post #143997 1st Oct 2012 3:18pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Is there any way to set FHM to turn on automatically without having to flick the high beam?
I have gone through the menus, but can't see what I'm doing wrong.
Any help greatly appreciated.
Thanks.
Post #144032 1st Oct 2012 5:37pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
Does anybody actually read the previous pages?
F
Post #144044 1st Oct 2012 6:20pm
Stryke
I did read the previous page where a comment was made that the lever had to be flicked once the ignition was off.
I wondered if there was any solution or any future plans by GAP to automate the FMH feature...
Post #144078 1st Oct 2012 8:27pm
The usual response from the guys at GAP is that they don't introduce something that's not there, so if the FMH function needs to be activated in a certain manner, that's the way it works! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #144083 1st Oct 2012 8:43pm
SteveMFr
Site Sponsor
Exactly! Thanks Alan.
This is exactly the problem. We can't program freely - we are only giving access to options programmed into the ECUs by LR (or BMW).
FMH on early L322s is activated by leaving the lights on until the ignition has been switched off. AFAIK there are no other options avail for this.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #144088 1st Oct 2012 8:57pm
Always glad to help Steve! Thumbs Up Very Happy Got - 2017 SDV8 Autobiography in Loire Blue
Post #144089 1st Oct 2012 9:02pm
Stryke
It's a shame. My 2010 Sport has this option, unlock the car and the lights come on and lock the car and the lights stay on (when its dark).
A lot of older mercs have this too.
Anyway, not GAPs fault.
Post #144106 1st Oct 2012 11:25pm
Hi Steve,
A few questions from me Smile
Is it possible to activate the lower tailgate solenoids from the IID tool?
Is it possible to hook it up to a PC at all to use a gui or CLI as a possible quicker way to navigate around?
Thanks,
Will FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #144134 2nd Oct 2012 8:47am
SteveMFr
Site Sponsor
Hi Will,
Unfortunately no on both counts.
I don't think that the tailgate solenoids and switches are on a bus - I believe they are just hard wired (have to check the wiring diags to make sure). So we have no access to them.
As for displaying the IIDTool menu - we have something coming but at the moment the USB connector is only for updates.
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #144153 2nd Oct 2012 9:41am
IIRC the rear lower actuators are activated by a pulse being sent from the switch. The switch pulse then goes to the BCM which is meant to trigger the actuators together to release the lower tailgate.
No worries about the laptop bit as i could live without it, just thinking ease of use for a CLI or Gui person in the future but it would add to the cost i guess. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #144157 2nd Oct 2012 9:44am
SteveMFr
Site Sponsor
You are correct - I checked in the workshop manual:
Upper Tail Door Internal Release Switch
The internal upper tail door release switch is a non latching push switch installed on the centre console. The switch
allows the tail door to be opened from inside the vehicle. When the switch is pressed a ground is connected to the
BCU. The BCU only responds to the input when the CDL system is unlocked and the vehicle is stationary.
Upper Tail Door External Release Switch
The external upper tail door release switch is a microswitch installed in the license plate lamp housing in the bottom
edge of the upper tail door. The switch is operated by a lever connected to a rubber covered plate set into the outside
surface of the license plate lamp housing. When the switch is activated it connects a ground to the BCU. The BCU
Lower Tail Door Release Switch
The lower tail door release switch is a non latching push switch installed under a rubber cover in the top edge of the
lower tail door. When the switch is pressed, a battery voltage signal is connected to the BCU. The BCU only responds
to the input when the upper tail door is unlatched and the vehicle is stationary.
Lower Tail Door Release Relay
The lower tail door release relay is installed on the rear fusebox. When the BCU receives a valid input from the lower
tail door release switch, it momentarily energises the relay to simultaneously activate the lower tail door release
actuators.
I will ask Christian as he is the one making decisions on this, but as this does go through the BCM we can control it. If it is included, we would include it in the final major FW release later this year as manual component activation is one of the items we do not yet consider complete in the IIDTool.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #144167 2nd Oct 2012 10:01am
Thanks Steve.
I do sometimes think if there is a trigger issue recognising the upper tailgate as open but the lights come on so it must be there and working Smile
Anyway i digress! Thank you for your input on this one Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #144194 2nd Oct 2012 10:33am
